Sponsored by:
Sponsored by: Sake Bomb
How to route new brake lines without ABS module.
Old 05-20-2015, 12:04 AM
Ek_Jak's Avatar
Default How to route new brake lines without ABS module.
Hello I looked everywhere but couldn't find any info on how to route brake likes during ABS delete... Any body with experience on abs delete?
Old 05-20-2015, 07:48 AM
yamahaSHO's Avatar
Curious as to why you're deleting such a wonderful systems known as ABS?
Old 05-24-2015, 11:02 AM
Slowcrash_101's Avatar
Maybe regulations? Maybe his modulator is wasted. Either way routing brake lines as convoluted as ours is no easy task. Furthermore the master cylinder only has 2 lines, so you would need a combination valve to replace the proportioning valve. If you're going to go that route I would replace the master with a true tandem master cylinder. That way you can control brake bias.
You would have to bend your own lines using the factory lines as a template. But you would also need to be creative with how you route the lines after the combination valve.
eastonh477
06-12-2014 05:57 AM
CHIPPO
02-12-2013 11:37 AM
Tech7427
02-20-2010 08:08 PM
Mr. Eryozgatliyan
06-22-2006 02:21 PM
WindchaserS2K
05-22-2006 01:05 PM
Quick Reply: How to route new brake lines without ABS module.
