Sway bars
Old 05-23-2015, 08:29 AM
MARC87's Avatar
Default Sway bars
Has anyone fitted a late rear sway bar to an early s2k?? Did it make any noticeable difference?? Looking to run a square tire setup with 245s all round and been reccommended to use a late sway bar to give more back end grip
Old 05-23-2015, 08:40 PM
MB
Member
MB's Avatar
Roll bars changed a lot between model years, so depends which MY you have and which one you want to go for. Generally they softened the rear arb and spring rates as time went on, to stop it being so snappy at the rear.
It's 'tyre' too, less of that US nonsense
Speaking of which, presume you have 8" plus front wheels to support the 245s?
Old 05-23-2015, 09:49 PM
MARC87's Avatar
Im going to be using 17x9s all round with 245s. I have a 2001 s2k so suppose i should measure the rear arb to see what i have although from the research ive done the 2000 and 2001 models had the stiffest arb of them all. Ive found a 2005 arb on ebay for cheap so was thinking this might be a gd purchase for more rear end grip??
Old 05-23-2015, 10:21 PM
MARC87's Avatar
Or there is a rear arb from a 2007 but assume these would be the same??
Old 05-23-2015, 10:45 PM
MB
Member
MB's Avatar
Best to check but allegedly this is the arb rates
Code:
              |  Front   Rear    |  Front    Rear
Model Year    |  Spring  Spring  |  Sway Bar Sway Bar
2000-2001     |   219     291    |   393      427
2002-2003     |   246     309    |   300      396
2004-2005     |   262     278    |   300      311
2006-2007     |   262     269    |   300      311
2008-2009     |   280     294    |   354      311
2008-2009 CR  |   384     343    |   392      362
Note 1: All figures are in lb/in. Divide by 56 to get kg/mm.
Note 2: Edited 17Nov2010 with slight updates to spring rates per rev1 of paper.
I'd always advise changing the rear ARB so it's equal to or less than the front (depending on spring rates) on an S2000, but it's a very personal thing.
CR is perfection imo, they got all the balance where I like it.
Old 05-23-2015, 11:51 PM
MARC87's Avatar
I think ill get the one off ebay and give it a try. Thanks for replying
Mugen_is_best
10-17-2018 10:22 AM
dewey
03-30-2009 06:39 AM
scirocco25
07-21-2008 05:23 PM
cordycord
09-28-2004 08:07 AM
krazik
04-16-2003 01:25 PM
Quick Reply: Sway bars
