Air con cold temp?
Old 06-30-2015, 10:51 AM
martin j's Avatar
Default Air con cold temp?
Been checking her Seat's air con efficiency and got a temp reading of 3*C, so I thought I'd try the S2, a few minutes running showed a reading of 5*C, is this low enough? Car is now 6 years od and the air con has never been touched, is now the time to have it done? Been quoted £35 by one of my customers(Kia main dealer) who bought the latest re gen machine recently from me, I know the techs there who do a good job so is £15 cheaper than the Honda dealer worth a go?
I have tried a search but not found the answers I needed BTW.
Old 06-30-2015, 10:55 AM
NicoS's Avatar
I just had my car serviced last friday, they checked the aircon and said it was running at 9*c, anything above 6*c they recommend getting it serviced so I guess you're fine.
Old 06-30-2015, 10:32 PM
BenRNBP's Avatar
6 years for air con is a good stretch, tbh it's probably worth while getting it vacuumed down and recharged as the lube oil will be replaced too. If you can get a deal through your contact then I'd go for it (assuming the whole world hasn't gone outside and decided that today's the day to get their air con fixed )
Old 07-01-2015, 12:33 AM
U9aXy6Dn's Avatar
Air con is the only thing I haven't had 'serviced' since I have owned my car - however that will change as soon as I get it back.
Old 07-03-2015, 06:16 AM
Nick Graves's Avatar
Well, you sold him the machine - where's your product faith?
Truthfully, six years is a good time for a suck & blow - the lube will need changing and a repressure will make it icy cold. Might also reveal a leak issue, if there is one.
Mine's not been done admittedly, but I hardly ever use it. Other than to circulate the lube...
I should get the Leg End done, as it doesn't feel quite as icy as I think it should. It made a massive difference to my old Prelude, but then I could hear gurgling in the evaporator, which was a pretty clear sign it was long overdue.
Old 07-03-2015, 07:50 AM
CHIPPO's Avatar
In the s it still works fine after 14 years
Audi A4 is nowhere as efficient !
Old 07-03-2015, 09:41 AM
cheshire_carper's Avatar
I'd leave a window open on the a4 for when Mrs chippo is stuck and its 30 degs
Old 07-03-2015, 12:03 PM
CHIPPO's Avatar
Mr Carper you sure like to sail close to the wind !
Old 07-03-2015, 12:42 PM
I know how shit your central locking is.
martin j
05-15-2014 12:39 PM
Jsmakr
07-16-2008 09:24 AM
MGrant
Car Talk - Non S2000
13
04-25-2007 09:09 AM
ninegrand
07-12-2003 03:46 PM
mpikounis
06-18-2003 10:30 AM
Quick Reply: Air con cold temp?
