engine dies at idle
Old 08-11-2015, 09:57 AM
SoREALemjay's Avatar
Default engine dies at idle
MY00. No cel. Starts and drives fine. When pulling to a complete stop my idle would drop to 100-200rpm and stutter/shake. Sometimes it dies and sometimes it goes back to its normal idle. Starts up fine when it dies. I know for sure my motor mounts are done but could that be it?
Old 08-12-2015, 06:44 PM
Bump
Old 08-12-2015, 08:06 PM
meccjoo's Avatar
Try cleaning your IACV, there is a guide somewhere on here.
Old 08-12-2015, 09:44 PM
braeden's Avatar
Seconded
Old 08-18-2015, 07:17 AM
kevinahn549's Avatar
Sorry for the late response. If your issue isnt fixed i would check out the O2 Sensor. Mine did the exact same thing, when i let off the gas the rpm would drop to 1-2 bars ( 200 -400rpm ) and either die or go back up. Found out it was my o2 sensor that died, replaced it and the idle never drops that low after letting off the gas.
Old 08-18-2015, 11:14 AM
dakao's Avatar
I would just clean the intake throttle with the injection or carburator cleaner spray...
Old 08-19-2015, 04:23 AM
clio's Avatar
+1 iacv valve as first culprit
91crxSi
07-19-2023 03:01 PM
keysley
04-15-2012 01:47 PM
simonix
06-15-2011 09:01 AM
tlogic
11-06-2009 11:03 AM
nightcrawler7188
07-04-2007 01:22 PM
Quick Reply: engine dies at idle
