DIY dropped a valve?
Old 10-01-2015, 10:05 AM
duhwinning's Avatar
Default DIY dropped a valve?
Last week i was doing a valve replacement and adjustment for a 2002 AP1 to AP2 retainers and keepers/cotters intake side ONLY. Long story short I forgot to pressurize the cylinders thinking by sticking the compression test tool in it would automatically do it. But no, the retard that i am assumed it was pressurize so i borrowed a special tool that would knock out the old AP1 retainers and keepers/cotters from my buddy like the one this guy used in this video http://youtu.be/zFmC66YU6zI . So I was knocking and knocking then BAM my 2nd valve in cylinder 2 fell (clank Clank noise in the cylinder). So bummed out I was already thinking about taking my ENTIRE head off. YES, my entire HEAD which means take apart intake mani, exhaust mani, and timing chain and oh lets not forget the serpentine belt too right? I was like hell i mine as well go with ferrea valves and valve guides with supertech dual valve springs and retainers. AWWw heoL Nah I AIN"T GOING DOWN LIKE THAT GIRL....
So heres my little contraption on how to retrieve your valves without pulling your head. I did a little research and found a supra guy who had done this successfully. LINK: http://www.supramani...moving-the-head! READ that lol.
Depending which valve you dropped i'm sure it will work for exhaust and intake
so if its exhaust use this link to take it apart https://www.s2ki.com/...nd-diy-install/
so if its intake use this link to take it apart http://www.s2000.org/mods/insulator/
Now once everything is pulled off and put to the side the tools you need is:
1 Krazy Glue (yes KRAZY GLUE from 99 cents Store)
1 Shoe lace (vans rounded works or anything equivalent to that which would fit into the valve stem seal hole the smaller the better)
1 smallest telescopic magnet (bought from auto zone for 2.99)
2 pc needle nose pliers 6 inch long i believe (bought from harbor freight 8.99)
1 acetone bottle (girlfriend gave it to me saved a few bucks why not)
Are you ready? This is where the fun begins. No really this is fun stuff and it may take a few tries.
First, off use the magnet to pull the the valve out from the which ever side you dropped the valve, in my case it was the intake side. You can't completely pull the valve out from the intake port but you can expose the very top of it just enough for you to clean the very top of it with acetone. This helps with wiping the oil and debris off. Now that you've prepped the valve stem next your going to put it off to the side with the magnet attached to it remembering to clean if it drops and hits any debris. Next fish your shoe lace plastic end of course going down to the valve stem seal into your head. You'll see it slither out like a worm now use your finger or a flat head to catch it and pull it towards you. Now use the acetone to clean the plastic tip of your shoe lace making sure everything is dry from the acetone and apply a dab or very small amount of crazy glue to cover the very end surface (thats a circle surrounded by plastic but the middle consists of your shoe lace material) this part will attach to the very top of your valve stem.
NOTE: more glue does not mean better. That means worst. You need to sustain the girth of the valve stem and have nothing in the way when making its way back up the valve guide.
The shoelace tip is perfect since it is smaller than the girth of the valve stem. Next let it dry for like 5 to 10 minutes. Had a few laughs and cracked a few jokes with my buddy who was helping me. Hes also on this forum too.
After its done drying let go of the magnet and let the valve drop in its cylinder. Now straighten out that shoe lace because there should be some slack when you glued the ends together so when you pull its just a straight shot.
Rremember those handy 6 inch long nose pliers from harbor freight? I used electrical tape around the jagged edges on each side to not scratch/damage the valve stem. Now heres the tricky part you can't tug too hard because the glue point will snap so tug on it just a bit until the valve touches the valve guide. As soon as the valve touches the guide I stuck the needle nose in and helped guide it in the best i can until i felt or atleast saw the tip was in. Now lightly tug on the shoe lace and your valve should slide right back in. It took me two tries to be exact not accounting for all my other attempts with speaker wire, clothing hanger, spliced usb wire, and probably other stuff
Thats right people there you have it I got my valve back in with a shoe lace and krazy glue. It's been proven. No pics taken because i nearly shat myself when i accomplished this.
Scott W Howard (11-24-2020)
Old 10-04-2015, 06:05 AM
MM3Kwolik's Avatar
This thread is awesome. That's some ingenuity if I've ever heard of it. Probably a huge pain in the ass, but much easier than removing the full head and reinstalling (much cheaper too).
Old 10-04-2015, 03:47 PM
miloking's Avatar
or you can just stand the valve up in the cylinder, line it up with the hole and crank the motor...it will push it right back up
edit: its a joke dont do this anyone....
Old 10-04-2015, 04:08 PM
freq's Avatar
So proud he made 2 threads!!
Old 10-05-2015, 07:59 AM
MM3Kwolik's Avatar
I was thinking the same thing.
Old 11-23-2020, 03:51 PM
S2K-lester's Avatar
Default Success!
thread revive!
I want to thank the thread poster for the the inspiration. My valve dropped too, along with my heart. Couldn’t believe it. I sat down defeated in disbelief. Then I got back up and found this thread and a YouTube for inspiration. If you drop you valve, it isn’t the end of the world! I wanted to let future valve droppers knowYou can still retrieve it.
Use this YouTube link, get this magnetic worm tool and endoscope to perform this. Make sure you shrink wrap the end of the magnet for insurance it doesn’t come off like the YouTuber
V8 Tools 3826 Mighty Worm 26" Flexible Magnetic Pickup Tool
Amazon Amazon
DEPSTECH Wireless Endoscope, IP67 Waterproof WiFi Borescope Inspection 2.0 Megapixels HD Snake Camera for Android and iOS Smartphone, iPhone, Samsung, Tablet -Black(11.5FT)
Amazon Amazon
duhwinning
10-27-2020 02:56 AM
duhwinning
10-06-2015 03:47 PM
SpitfireS
02-01-2013 02:34 PM
Boofster
04-01-2011 11:22 AM
Quick Reply: DIY dropped a valve?
