Best place to rebuild bottom end? (Solved)
Old 10-20-2015, 06:39 PM
DutchyFutch's Avatar
Default Best place to rebuild bottom end? (Solved)
Hi guys,
I'm having a big issue right now, my first engine spun a bearing on cylinder two , it seized the engine at 14MPH.
I was running 3 quarts low unfortunately because I had the car stored and I guess something either leaked out into the drain in the floor
or something else. Whatever it is, my car is broken. I swapped the engine out and it's out the car.
I took the bearing off cylinder 2 from the bottom after taking the oil pan and cover off. It cranked again by hand.
I want it to get fixed properly , I don't know how much it would cost and where to even go to
Could anyone help me ? I need new bearings and most likely a new crank. I don't know if the cylinder walls are scored.
all I know is that the head came out fine.
Should i dissasemble the head from the block and inspect it or just bring it to a machine shop? If so which machine shop should I go to?
Thanks.
I live in Cambridge so anything around boston/malden/lynn/revere would be great.
Old 10-21-2015, 07:55 AM
AZfury's Avatar
First I would disassemble everything to check for scores etc, at this point the crank and rod bearing will def need replacing, check cylinder walls for scoring and if there is scoring, that will need to be fixed...you may just end up needing a whole new bottom end. Let us know anything else you find out
Old 10-22-2015, 05:15 AM
Pinky's Avatar
Look up Ballistic Motorsports in New Hampshire. Now part of Granite State Dyno. I follow them and I think this month alone Scott has swapped out 3 engines!
Old 11-11-2015, 03:46 PM
I've swapped my car before myself I can rebuild it myself , I've talked to scotty, friends on facebook with him.
Old 03-02-2016, 10:23 PM
I opted out to buy an engine local with 59k miles for 2500$
I might just make an F24 engine out of the seized one.
cotte062
02-01-2019 07:22 PM
A.h
09-03-2012 06:06 AM
supahman04
06-17-2008 09:26 AM
g352s2k
06-30-2007 01:29 AM
Boit
Member S2000 Classifieds and For Sale
03-15-2004 03:21 PM
Quick Reply: Best place to rebuild bottom end? (Solved)
