Nardi Deep Corn Sterring Wheel... LOOSE HORN BUTTON!
Has anyone had this issue? I have searched and searched some more and have found nothing.
The horn button snaps in, but then has a little bit of up & down free play and will also spin freely. I ended up putting very small strips of double-sided tape along the back outer edge of the horn button where it touches the steering wheel. This helped, but it is still not as tight as it should be and is a lame way of "fixing" the issue.
I could add some pictures but I'm not sure it would help. I'm just looking for other people who might have this same exact setup.
WHEEL: http://www.amazon.com/Nardi-Steering.../dp/B005H8NNV8
HUB: http://www.evasivemotorsports.com/mm...Code=WORKS_HUB
ADAPTER: http://www.evasivemotorsports.com/mm...ry_Code=WB-PCD
Thanks!
Thanks!
