Timing Chain Tensioner - rattling
Hi - hoping someone might be able to offer me a bit of guidance...
Main dealer, after a service, has informed me that my engine is making a bit of noise, and it needs the TCT changed.
I have come across diy guides on fixing it by sandblasting or dremel'ing the worm bolt... - but then a guy on the US forum has stated that that's not the fix, and that dremel'ing the worm is only a temp fix... and, replacing the TCT is only a temp fix too (although how temp he doesn't say)...
I'm left a bit confused, - as to what to do then?
Also - can someone confirm that this is the correct part?
https://www.tegiwaimports.com/genuin...2000-f20c.html
Lastly, - am I ok to drive the car - or is it at risk of causing a bigger problem...?
Thanks for any help here.
I had mine changed for one with the enlarged oil pathway - no problems since. I think ESEM was doing this on an exchange basis although i could be wrong.
UK Moderator
This sticky post may be of help. https://www.s2ki.com/s2000/topic/108...t__p__23173842
This recent thread on the same topic also provides some good info: https://www.s2ki.com/s2000/topic/1142357-uprated-tct
You're fine to drive the car.
Used a Dremel mine 4-5k ago,and still no problems
I did no other modifications.
Do a search on Ballade / Billman TCT, this seems to be a good permanent fix.
Amazing - thankyou so much everyone for the great information and such a quick response... really is very much appreciated. Peace of mind that the car is okay to drive also, as I couldn't do without it this weekend.
