Half shaft spacers?
Half shaft spacers?
Has anyone thats on coilovers used half shaft spacers? Or not used them and thoughts on using them? I've gone...pretty low and was wondering if anyone has used them or not used them and regretted it
That does ring a bell. Its pretty low right now. Not sure how much i will have to check. I went with a small drop first (esipilar super down lowering springs iirc) and now its even lower. It scrapes on some of the larger speed bumps. Any idea where to get decent ones? Seen some 2 peice jobbies on ebay for £90 odd
Waste of £90
swap your cv joints round if you think its needed <you get vibrations>
lowered mine 25-30 at rear and is fine with 100kmiles Eibach springs,if i get vibrations I would swap them round.
plenty of how too"s and the reasons why to,do a search
You only need them if you feel vibrations. I felt vibrations as soon as my coils went on, the half shaft spacers worked for me.
^I'm in Canada and bought from one of the vendors.
I've fitted the Megan Racing split spacers so you dont need to remove the complete shaft. Quite expensive in the UK, but ordered mine as a bulk from the states (LSD, who is a trader on here) sorted me out with rear toe arms, shaft spacers and steering rack spacers. At the time it worked out almost half the price of all the bits would cost in the UK.
In all?
