Hardtop fitting kit removal
Old 04-06-2016, 07:44 AM
PJD
PJD's Avatar
Default Hardtop fitting kit removal
Is this an easy job for a layman?
Is there any dummies guides out there on how to do this? I have searched and found guides on how to fit a new hard-top, and photographs of exactly comprises the fitting kit, - but I haven't found a guide on how to simply remove the fitting kit as yet?
Thank-you for any help.
Old 04-06-2016, 07:56 AM
Tifosi Red's Avatar
Hi PJD,
I fitted my hardtop (this was a MY01 mind) and recall that the process was quite straight forward; the only fiddly bit was correctly setting the hardtop clearance. It would be a straightforward process to follow the install instructions in reverse to strip out the kit but that does rather assume you have the original components (striker plates above the windscreen, trim panels etc.) to reinstate once the hardtop specific parts have been removed.
Tif
Old 04-06-2016, 07:58 AM
PJD
PJD's Avatar
Originally Posted by Tifosi Red
Hi PJD,
Tif
Thanks, that sounds encouraging. Yes, I have all the original parts as my car is an original GT.
Old 04-06-2016, 08:14 AM
Santenay's Avatar
Pm me as I have the fitting instructions for the hardtop fitting kit that I could email you. It is an easy job to fit the side catchers. The bolts that hold the catchers are slightly longer than the bolts on the roadster.
Old 04-06-2016, 08:16 AM
shari7's Avatar
https://www.handa-accessories.com/S2000/s2k2top.pdf
this should help hopefully
Old 04-08-2016, 03:23 AM
PJD
PJD's Avatar
Many thanks Santenay for that kind offer. It looks at though what shari7 has posted is the same?
Many thanks Shafi7 for that.
Much appreciated
Old 04-08-2016, 09:37 AM
shari7's Avatar
Much appreciated
You are very welcome. Good luck.
Sent from my SM-G935F using IB AutoGroup
Old 04-27-2016, 07:04 AM
PJD
PJD's Avatar
Quick question - do I need to remove the HT in order to remove the fitting kit?
Old 04-27-2016, 03:33 PM
S2K_Nav's Avatar
Yes and if you are looking to sell the kit PM me a price!
s2konroids
11-28-2011 11:17 AM
mega_stream
05-23-2009 10:39 AM
jayjaydlc
09-29-2007 02:55 AM
silviaks
10-21-2005 04:34 AM
RHAP1CD2
01-24-2005 10:54 PM
Quick Reply: Hardtop fitting kit removal
