Steering Wheel Splines
put the bolt on there and tighten it down slowly (to 29 ft lbs). I put a bit of anti-sieze on the threads to make it easier to remove in the future, not totally necessary though.
You'll probably find that your estimate of straight isn't 100% straight when you get it out and drive down the road, so you may need to reset the wheel or get an alignment.
My thoughts are the clock spring may not be aligned,<squib>
just a thought
just a thought
I checked that 10 times, I even put paint on the wheel spindle cut out, and the paint landed on the white plastic cut out perfect.
Just seemed odd with the 1/4" gap.
it will be flush by the time you tighten it down. You can test it out by tightening down the bolt and then removing the bolt and you will see that the gap has closed up. The fitment is slightly tight so it doesn't fully seat until bolted down.
gizzard
02-05-2013 11:24 AM
