Brembo Discs
Brembo Discs
Hi All
I'm looking to upgrade my brakes
Looks like brembo discs from searching the interweb are not avalaible
Anyony know of a supplier or the best alternative make
Steve
Steve
Dixcels are a very good quality (and price)
If I was looking for standard discs I would go to my nearest euro Car Parts and buy some Pagid discs, they are about £90-100 the pair and are of the very highest quality.
Banned
Lots of info on the DIXCEL's here or drop me a message.
https://www.s2ki.com/s2000/topic/108...p-and-running/
Anthony
Anthony
Probably most are the same anyway -agree a good motor factors
Thanks for the replies
As noted above was looking for upgrading disc's as intend to do the odd track but want to keep calipers standard to keep the car standard looking as possible
Was thinking about brembos as I'm told they are the best
Are dixcels drilled/slotted ?
Its not really that clear
UK Moderator
Dixcel do both slotted and plain discs. An "SD" suffix signifies slotted, and "PD" is not slotted.
Banned
We have many people using both the PD and SD rotors or the high carbon FP or FS rotors on track and street. The High carbon heat treated rotors are a bit tougher when it comes to being abused for prolonged periods of time. This is why they are a favourite to competitors in series like Super Tiakyu where the OEM rotor dimensions must be retained.
A rule of thumb with slots is: a rotor with 6 Slots per side will increase the overall braking performance by up to 20% but increase pad wear rate by 30% on the road and up to 50% on the track.
As an occasional track day go'er you might find that a good compromise would be a slotted SD rotor with an ES pads. This will give an affordable but capable package that will behave quietly and reliably on the road.
An alternative would be to take the PD rotor with the more capable Z type pad. Again you will benefit from quiet civilised operation, great pedal from cold and great on track performance.
Either option comes in around £200 for the front axle.
I highly recommend matching front to rear axle. So if you do a slotted rotor on the front do the same on the rear with the same pad! This is VERY important to braking performance and reducing stopping distance.
Let me know if you have any other questions.
Regards,
Anthony
Regards,
Anthony
