Oil Leak
Old 04-28-2016, 02:30 AM
GeordieWaz's Avatar
Default Oil Leak
I have a slight oil leak from the allen bolt on the front of the engine, i know its the bolt that keeps the timing chain and cams in place so will not be removing it in search of the answer just now so don't panic!!! i do however know that there is an O-ring behind it and that it has the part number 91301-PCX-003. What i do need help with is finding this part for less than £5!! any ideas?
Old 04-28-2016, 03:04 AM
Daytona-Dave's Avatar
Why
Old 04-28-2016, 03:22 AM
GeordieWaz's Avatar
Originally Posted by Daytona-Dave
Why
because £5 plus postage for an O-ring is daylight robbery and why would you leave an oil leak?
Old 04-28-2016, 03:44 AM
Originally Posted by GeordieWaz
Originally Posted by Daytona-Dave' timestamp='1461841499' post='23950948
Why
I wouldn't leave the oil leak, Did i suggest that
Old 04-28-2016, 04:01 AM
GeordieWaz's Avatar
You didn't say that but the "why?" could have meant any part of my statement. So i just replied covering both parts. I wasn't looking for slightly arsey comments or pedants. Just a little bit of help to save several hours of searching through UK/USA websites if someone knew of a parts place that was reasonable. If i find a cheap parts shop id happily share the info!
Old 04-28-2016, 04:18 AM
johnckeen's Avatar
you'll need to take yours off and measure it then go hunting, but to be honest, its only £5 and that will give you piece of mind too plus its genuine part designed for it.
Old 04-28-2016, 04:19 AM
It isn't an arsey reply it was a genuine question, Why would you want to buy a cheap seal that may be of the incorrect compound of rubber and could suffer premature failure, or £5 pound for a genuine seal for an 3k engine, if you could find an equivalent part that was saving you say 20 or 30 quid then i understand but i wouldn't skimp on seals
Old 04-28-2016, 05:49 AM
Chuck S's Avatar
I believe you can replace the O-ring by backing the bolt out just enough to get at it. There was a thread recently where a curious owner completely removed the bolt (!) and there may be the information you need in that thread.
-- Chuck
Old 04-29-2016, 02:23 AM
Nick Graves's Avatar
You could have earned an extra £5 in the time it's taken to post this thread.
Old 04-29-2016, 06:29 AM
BenRNBP's Avatar
If you want use the cheapest o-ring you can find, some measurements that work are here https://www.s2ki.com/s2000/topic/832...g-weeping-oil/
Quick Reply: Oil Leak
