Sponsored by:
Sponsored by: Sake Bomb
Eibach issues
Old 05-06-2016, 05:49 AM
Conedodger's Avatar
The OEM service manual specifies where ride height should be measured. Like others have said, the body can be very inconsistent and is not a good place to measure. The rear should sit higher than the front. The factory built in a "rake" when they set up the ride height. I believe the Eibach's maintain the factory rake angle front to rear.
Old 05-06-2016, 06:39 AM
B serious's Avatar
Received 1,247 Likes on 944 Posts
^that can only be checked on a drive-on lift.
Any ride height, however, should really be measured on a LEVEL surface. Most parking spaces are not level.
Old 05-06-2016, 11:55 AM
Conedodger's Avatar
I made a homemade tool out of a piece of steel rod and a zip tie. Line up the rod under the control arm, slide the zip tie up to the bushing bolt center point, and then measure the distance with a steel ruler. Was able to do the measurement with the car parked on my garage floor.
Old 05-06-2016, 03:30 PM
B serious's Avatar
I use my eyecrometers
Old 05-08-2016, 03:33 PM
rbtz's Avatar
So what I'm gathering is this doesn't seem to be a big issue, as in I should be fine doing an entry level track day or auto X.
As for coilovers I plan on going that route eventually, but not until I'm no longer driving this in the winter.
Old 05-09-2016, 11:46 AM
Davo307's Avatar
My rears sit a 1/2" higher I'm the rear. Have tracked for 2 years this way with no issues. The downforce from the wing squats the rear and levels it out anyways. You're fine, get out there and enjoy some track time!
Danwolski
10-12-2012 03:19 AM
rob!
11-06-2008 07:54 AM
D Loke
10-20-2008 09:35 PM
yungjoc
06-10-2007 04:48 PM
johnqt3
04-23-2007 07:49 PM
Quick Reply: Eibach issues
