Minimum drop on Ohlins?
What would be the bare minimum drop achievable with Ohlins DFV coilovers?
I'm not interested in stance and more importantly my driveway is such that I only just clear at standard ride height!
Thanks
Thanks
They will go 20mm higher than the specified & recommended 20mm drop from OEM.
The minimum recommended drop is 10mm as you can read from the manual posted.
You could probably go a bit higher than that though, but they advice against this since the damper body make come loose from the lower bracket.
Kshawn
02-17-2019 02:14 PM
