Custom BBK Front & Rear
#22
The popular BBK for this car like AP racing and Stoptech etc maintain factory bias without addressing anything in the rear, simply due to proper rotor and caliper matching for the front.
But really, if your maintaining the stock tire sizing, you may not need a BBK at all, other then for bling factor. You may not be generating enough traction to generate heat/fade issues. I still track OEM brakes with 255/295 stagger, and air ducts mind you to help regulate. For my track they hold up reasonably. Im a heavy late braker, pushing them to the max as well. I probably should have a BBK but I make do without. They aint cheap.
http://www.sakebombgarage.com/ap-com...-system-s2000/
https://www.s2ki.com/s2000/topic/114...kit-group-buy/
#23
#24
I thought one of the prime reason for using the OEM or RX-8 caliper in the rear was to maintain the parking brake. If making an adapter bracket, I would have thought PFC, AP, Wilwood and others would all have calipers that would work in the rear.
In off-road trucks and some Cobra kit cars (and presumably other kit cars) a parking brake on the drive shaft is used.
#25
Originally Posted by SBGarage' timestamp='1467676384' post='24009077
[quote name='s2000Junky' timestamp='1466815673' post='24001874']
[/quote]
Correct, if you add our RX8 conversion rear kit you'll maintain roughly proper rear bias, as well as have a performance rear to match with a directional vented rotor (lots of benefits but I won't spam up your thread here). You can read about it more in our other threads... product link here. It contains everything to be full plug and play.
http://www.sakebombgarage.com/sbg-co...-retrofit-kit/
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
Urge
27
07-30-2015 05:52 PM
