S2000 Body and Paint Body kits, paint, ding repair and related discussions
DIY Rear Quarter Panel Replacement
Old 07-22-2016, 04:31 AM
Heags26's Avatar
Default DIY Rear Quarter Panel Replacement
Hello All,
A while back I put my S2K into some barrels during an autocross run and ended up damaging the passenger side of the car. Front fender, passenger door, rocker, and rear quarter were all destroyed in the process. I've already replaced the front fender and passenger door. I bought a donor half car from a junk yard and drilled out the spot welds that surround the rear quarter panel and rocker.
I'll be starting to drill spot welds on my car soon and am looking for any advice to avoid getting myself into a bind. Should I put the car up on jack stands to make sure the car is level avoiding body twist? Are there specialty tools other than a spot weld bit and an air chisel I should be looking to get? The rear quarter and rocker came off the donor car in one piece so hoping to put them on without splitting them at the rocker seam. If there's any links, tutorials, videos, etc. of how people in the past may have done this, I would greatly appreciate it.
Thanks in advance for the help!
Old 07-23-2016, 07:31 PM
cleenyc99's Avatar
i'm not really sure what u need to know sounds like your off to a good start. I replaced my quarter came out grate. lmk if you got some questions here's a link to my tread https://www.s2ki.com/s2000/topic/113...d/page__st__25
LVGPWS2K (01-04-2018)
Old 07-25-2016, 03:57 PM
Heags26's Avatar
Thank you for the link! I may have missed it, but what spot weld bit did you use on the damaged panel? I used a Harbor Freight one on the donor car and it worked well for that but I noticed the style of the one you used was different. Did the one you used cut the spot weld down as opposed to cut around it? Which would require grinding each weld down before putting the new panel on. Thanks again!
Old 07-26-2016, 06:17 PM
cleenyc99's Avatar
don't remember the brand but something like this http://www.autobodytoolmart.com/tita...m-p-10932.aspx
don't drill to fast or push to hard and brake the bit they ant cheap. I used one bit for the hole project
Old 01-04-2018, 01:39 PM
LVGPWS2K's Avatar
CLEENYC99: I have some questions about replacing a rear quarter panel. Can you please contact me at teachvegas@yahoo.com
phongs2000
09-28-2015 07:02 AM
06Estukay
02-22-2015 03:52 PM
ta845
11-27-2007 05:34 PM
Dolemike
08-05-2004 10:08 AM
Quick Reply: DIY Rear Quarter Panel Replacement
