S2000 emblem removal and fitting
Old 07-27-2016, 12:06 AM
FreshDonny's Avatar
Default S2000 emblem removal and fitting
Hi all
I was thinking to remove the S2000 badge on the wing to spray it an anthracite/gunmetal colour to match my wheels and also ditch the little Honda badge above it.
To remove am I right in thinking just a heat gun and leverage to remove the badge and glue remover to get rid of the gunk?
but to re-fit, is there a special type of glue to use so not to damage paintwork if I want to remove again? or should I play safe and just use double sided tape and cut it out with a craft knife? anyone done this before?
Thanks
Old 07-27-2016, 12:34 AM
Mike's's Avatar
I would heat and use some dental floss behind the badge look on you tube for detailed videos
actually here you go video
Old 07-27-2016, 12:51 AM
kw_21's Avatar
Heat up with a hair drier and use dental floss or fishing line.
This should help when sticking them back on and just use 3M tape.
Old 07-27-2016, 06:24 AM
R5HKK's Avatar
Before you decide to do this please search removing s2000 emblem. The Honda bit is easy. The s2000 is a giant pain in the arse. It takes ages and is very difficult. I used hair driers wd40 and it was still almost impossible. Read the woes of other people before taking the s2000 bit off. After all this I would recommend instead painting it whilst on the car.
cpaforever
08-15-2013 04:22 AM
nutar
03-07-2008 08:04 PM
patinum
11-07-2005 05:08 PM
hornyhonda
08-03-2004 12:37 AM
Nixlimited
08-11-2002 05:11 PM
Quick Reply: S2000 emblem removal and fitting
