Axle Nut TSB - Sharing my Tools
Old 09-13-2016, 03:20 AM
Chuck S's Avatar
Received 1,131 Likes on 994 Posts
Tightening the nut to the next flat is what's required. Of course you need to know the start point. But you don't need a torque wrench, just a big breaker bar and 36mm socket. 180 pounds on the end of the 2-foot wrench handle should be enough. Maybe bounce a bit.
Remove the nut (the stake will come off as you loosen), clean and grease the nut, and replace to where it was. Tighten one more flat (another 60° since there are six sides). Re-stake.
-- Chuck
Old 09-13-2016, 11:20 AM
2000ths's Avatar
yeah, it looks like you didn't quite turn the nut far enough. as chuck mentioned it should go 60 degrees(1/6 of a turn) past the starting position. looks like you went 1/12 of a turn.
Old 09-14-2016, 09:43 PM
#172CR's Avatar
Originally Posted by Wobster
Originally Posted by #172CR' timestamp='1473519207' post='24058985
[quote name='Wobster' timestamp='1472350654' post='24049321']
Is this for all years or limited to certain years? Did Honda ever issue a tech bulletin on this or is it something Billman just learned through experience?
This was for all model years; 2000-2009
So there is no actual recommended torque spec, just this method, is that correct?
ETA: it looks like Billman is estimating 380-400 ft-lbs
https://www.s2ki.com/home/2012/09/21...ow-to-and-why/
Where did you see Billman estimated ft/lbs that high? Getting the stake point moved from a start point (12) to (2) has been adequate for most owners.
Had to go back and research...it wasn't Billman, it was another member (my mistake) you can see it here , later in the same thread In post #231 another person did it and estimated 400-480 ft-lbs and in the next post Billman states his approach was right on...Clearly this should be done the way Billman described it, I am curious as to torque spec as I may occasionally have access to a 600 ft-lb torque wrench so I am curious.
[/quote]
Gotcha! I bet the torque spec's vary quite a bit depending on each car and getting that dang nut moved 1/6th of a turn!
Old 09-15-2016, 02:39 PM
arsenal's Avatar
Well fawk by bearings and most likely hubs are toast. Originals on 174K and just started hearing dubstep as background music
Any recommendations on local shops for a press in the metro area? I can disassemble myself, just don't have a press
Old 10-02-2016, 06:43 PM
arsenal's Avatar
Originally Posted by arsenal
Well fawk by bearings and most likely hubs are toast. Originals on 174K and just started hearing dubstep as background music Any recommendations on local shops for a press in the metro area? I can disassemble myself, just don't have a press
Tried searching around - any thoughts or does anyone have one ??
Old 10-03-2016, 04:52 AM
cdelena's Avatar
Some machine shops will do the work and sometimes you can slip into a transmission shop to get a little time on their press. I was frustrated when the manager at the place I wanted to use decided he wanted a minimum of two hour shop time (@ $74 per hr) for each visit. So I went to Harbor Freight with a coupon and bought a press at a little over $100. Mine is not easily accessible and since it has to be dragged in and out of the garage for use I don't offer it, but if you have the room you can buy a press.
NFRAP1
San Diego S2000 Owners
08-27-2007 11:55 AM
Kel
27
05-26-2006 09:50 AM
3ngin33r1
10-18-2003 10:01 PM
wantone
10-12-2002 09:46 PM
Quick Reply: Axle Nut TSB - Sharing my Tools
