260whp with bolt ons, cams and headwork?!?
#31
Originally Posted by takchi' timestamp='1472691204' post='24052422
For reference, Church Dynapack numbers:
240hp = Stock CR
255hp = CR + Berk 3" Headerback (Catless) + tune (91ACN)
166hp = Stock BRZ 4th Gear Pull
172hp = Stock BRZ 5th Gear Pull
Same day, EAS Dynojet numbers:
210hp = Stock CR
220hp = CR + Berk 3" Headerback (Catless) + tune (91ACN)
173hp = Stock BRZ 5th Gear Pull
Hard to say what's causing the discrepancies, but we should note deltas rather than absolute numbers when working with the dynos. When working with deltas, percentage is much more realistic than actual difference in values.
240hp = Stock CR
210hp = Stock CR
If only the new Miata could put down that kind of power! Good thing it weighs 500lb less then an s2k so it can still have a fighting chance against a BRZ
#32
Ya know... I wrote an article way back in the day about dynos and why you shouldn't compare between them. What does matter with a dyno is that it's consistent, repeatable, and precise (different than accurate).
http://www.motoiq.com/MagazineArticl...lieve-One.aspx
I dyno'd my S2k at Church when I did a KPro install on my car. Dyno'd at 238hp completely stock on Shell 91 octane. Then after the KPro install and Church tuning it, it put down 247hp. Are the absolute values of 238hp and 247hp important? Not really. What is important is the 247/238 = 1.0378. So if I got 210whp on a Dynojet stock, I'd expect about 218whp after the KPro install and tune.
http://www.motoiq.com/MagazineArticl...ter-Power.aspx
Anyway, based on the numbers of various cars I've seen at Churchs, I'd say his dyno basically gives off crank hp numbers.
240hp = Stock CR
210hp = Stock CR
240hp = Stock CR
210hp = Stock CR
Originally Posted by s2000Junky' timestamp='1473450145' post='24058520
[quote name='takchi' timestamp='1472691204' post='24052422']
240hp = Stock CR
210hp = Stock CR
240hp = Stock CR
210hp = Stock CR
[/quote]
Power is not really a strong point of the BRZ. The torque is actually pretty good with the right header and a very refined tune. The chassis is very good and the stock body lines promote very good aero. To validate this point, we pit a drag race from 80-130mph between a tuned CR with headerback against a factory BRZ. From 80-100, the CR was pulling pretty nicely, but around 100-130 is where the biggest surprise came...the BRZ actually keeps up with the CR and holds its position all the way to 130mph. In that effect, the sleek BRZ lines definitely helped over the high drag CR. A Voltex S2000 that I've toyed with produces high downforce, but also yields pretty significant drag (car slows down quickly if you let off the throttle).
On top of that, you can literally toss the crap out of the BRZ in high speed corners and not really spin out with stock or motorsport grade suspension. The car is very predictable and every S2000 driver that moved to the BRZ has noted how easy and safe the platform is. I can go on and on about it though since I own a CR and a BRZ.
#33
I was recently at Church and watched a BRZ with jackson racing (stock boost I believe) kit with c30 supercharger I believe and after tune it just barely hit 300! BRZ's don't respond to boost as well without some work it seems compared to our motors with their good flowing heads. People keep chiming in and saying Church shows crank numbers, that is impossible unless the dyno was bolted to the flywheel/crank/output shaft, there are still losses of the drivetrain (transmission, driveshaft, halfshafts, wheel bearings, brake rotors, etc) on Church's dyno...if you use a whp to crank calculator which uses 15% loss like the one here (http://www.mk5cortinaestate.co.uk/calculator4.php), you will see that church and comparison dynojet to crank numbers don't line up, Church is still higher but not indicative of crank[shaft] numbers...you can only see those numbers without drivetrain loss on a proper engine dyno.
ie.
ie.
If we take that scenario with the mazdaspeed 3 as I mentioned previously, and use an example s2000 at 240whp on a well calibrated dynojet in the same city as the church's dynapack, same day, etc. Then you are looking at 261.84 at Church and ~280-282 at the crank.
#34
Just to add to this discussion, c38-91 kraftwerks s2000 381whp SAE correction dynojet 381whp then two weeks later 421whp on Church. That's a 10.5% difference between Church and SAE dynojet. So Church numbers are not crank numbers as some believe and SAE correction means a lower number than the usual STD dynojet numbers you see floating around. If you believe the S2000 has 15% loss and the SAE dynojet reflects a 15% loss, then Church is still 4.5% below crank numbers. Then again most people think STD reflects 15% loss and SAE is 4.5% lower than STD on average...so draw your own conclusion(s). If I compare Church to STD dynojet it would be more like Church was only 6% higher reading.
#35
So to find crank numbers if you believe SAE is the real number on dynojets, then multiply church's numbers by 1.045. If you believe STD dynojet, then multiply church's number by 1.09 to get crank numbers
#36
My prior motor was a BC2 cams with intake and berk header back with Kpro and a tune. Made 286 on his old calibration. Pulled the cams and lost 20hp.
So to the OP. With cams and all the other bolt on's you'll be close to your 260 whp goal. Throw a 70mm TB and bored intake and your closer.
But to get there without a shadow of a doubt do the 2.4 stroker and call it a day.
At the end of the day they are just peak numbers. Tune on a test pipe and get 80% of the fun for 10% of the price. But why listen to me when I can't take my own advice!!
#37
I'll second this. Same kraftworks kit on 91 hit 421 on Church's dyno. I ended up bringing down the redline which cut the peak.
FF2Skip
03-12-2007 05:58 AM
beroznikmal
06-09-2003 08:36 AM
