Mettalic Rattle between 5k-6k
Old 09-22-2016, 10:09 PM
ben5560's Avatar
Default Mettalic Rattle between 5k-6k
I had already posted about this, but it seems to have disappeared! I have an odd rattle inbetween 5-6k, happens in all all gears (well at least 1-3!).
I have tried searching, but not much luck. Any ideas? Loose heat shield, cat?
Old 09-22-2016, 10:14 PM
Spawn-uk's Avatar
Is it something that we would hear if you recorded a video?
Rob
Old 09-22-2016, 10:38 PM
RobinA3's Avatar
Loose cat heat shield.
Old 09-23-2016, 12:16 AM
noodels's Avatar
Was a Loose heat shield & cat on mine
Old 09-23-2016, 12:24 AM
gav86's Avatar
Loose cat heat shield on mine too.
Old 09-23-2016, 01:24 AM
Nottm_S2's Avatar
And mine
Old 09-23-2016, 05:49 AM
ben5560's Avatar
And it was always between 5 and 6k?
Just went to the local garage to get it booked in, described the issue, enjoyed the response I got...
'....how often do you get up to 6k!?'
...more often than you'd think!!!!! Obviously doesn't know VTEC!
Old 09-23-2016, 12:24 PM
simon.'s Avatar
cat heat shield for me too! Easy to remove with the right tools.
Old 09-24-2016, 02:19 AM
ben5560's Avatar
Is it safe to completely remove it? I'll pop down to quik fit (wouldn't use them for anything but little things like this) and ask them to rip it off!
Old 09-24-2016, 02:35 AM
tozerman's Avatar
I wouldn't personally, the cat gets bloody hot as you'd expect, they are there for a reason.
I would just get under the car and have a look your self, it is normally plain to see what's happening. There are also 3 heat shields on the manifold itself plus a locating bracket where the bolts can work loose.
Quick Reply: Mettalic Rattle between 5k-6k
