Squeaky suspension
Squeaky suspension
Anyone had problems with squeaky KW V3's before (or any coilovers for that matter), and if so, how did you stop it?
I can't be certain, but it sounds like the noise is coming from the top mount area, behind the boot trim. It sounds like a squeaky bed spring when I go over a biggish bump.
I've given them a squirt of lube but I haven't had chance yet to see if it's made any difference.
Just wondered if anyone has come across it before?.......
Cheers, FB
Cheers, FB
Assembled my coilovers with lots of white grease before install
Originally Posted by saero
Can you tell me where did you apply it? Did you put the grease between the spring and top mount or the top mount and chassi? What product did you use? <img src=/emot-tip-wink.gif' class='bbc_emoticon' alt='' />' />
I used GT85 first so that it would penetrate, then clear PTFE spray grease.
dctrpark
05-24-2004 07:22 AM
