£10 for an o-ring?!
Old 09-26-2016, 08:01 AM
nomadicS2k's Avatar
Default £10 for an o-ring?!
So cleaning out the throttle body and map sensor and I am blowing around the map sensor seat and blow out the o-ring. Lost in the engine bay somewhere never to be seen again.
A quick check on Lings - suggests a RRP of £7.31....
Are there any alternatives - I must be able to get a simple o ring from somewhere? Anyone happen to know the size?
Old 09-26-2016, 08:10 AM
Daytona-Dave's Avatar
Most garages or auto spare shops will carry O rings for a few pence
Old 09-26-2016, 11:00 PM
BenRNBP's Avatar
Love the engine bay - in theory everything should fall right out the bottom shouldn't it ? Never did find that fuel rail cover nut...
I have a box of Nitrile o-rings that come in very handy for occasions like this, they do most car jobs other than specialist uses where Viton or HNBR would be a better fit (e.g. Air Con) most motor factors will carry them for £12-£15 or so https://simplybearings.co.uk/shop/pr...ducts_id=60122
Old 09-27-2016, 12:15 AM
MB
Member
MB's Avatar
Anything near the fuel rail is a nightmare and will never be found, ever.
Normally I wouldn't muck around with or Rings and stick to OEM, but the MAP one I'd happily use something off the shelf if you can get the right size. Problem is most O rings are sold in kit boxes, so you might get 100 or so, for £20 but you will then have a nice collection.
Old 09-27-2016, 01:00 AM
Nottm_S2's Avatar
Haha
cant help on o rings but like the story
I dropped a bolt on an engine that wasnt even in the car.
2 of us couldnt find it.
We put the engine in a van, drove 80 miles, removed it, fiddled with bits and about a week later it was there on the floor, next to the engine.
Old 09-27-2016, 03:40 AM
WinFreak's Avatar
I dropped a nut into the engine bay of my old crx, 2 weeks later it muched the timing belt and the whole thing went pop...
Old 09-27-2016, 07:06 AM
SuperHamz's Avatar
Losing things in the engine bay is almost as bad as when you've got screws left over when you've put the interior back together
Old 09-27-2016, 11:10 AM
E4RTH WORM JIM's Avatar
I've got 15p nitrate o-rings on my ID1000 injectors. Been on four years and no issue. ID wanted about £20 delivered or something stupid.
They just have to be the correct rating for fuel applications.
Direct gaskets in Hull got me them. Ring them and they can source or cut anything you require. Great little supplier.
They've cut me a gasket for my Tial bov when I lost that, new exhaust gaskets and an exhaust manifold gasket, well I cut that but they provided the material
Old 09-27-2016, 11:33 AM
nomadicS2k's Avatar
I am feeling soo much better that I am not the only cluts!
On the scrounge tomorrow!
Originally Posted by BenRNBP
Love the engine bay - in theory everything should fall right out the bottom shouldn't it ? Never did find that fuel rail cover nut...I have a box of Nitrile o-rings that come in very handy for occasions like this, they do most car jobs other than specialist uses where Viton or HNBR would be a better fit (e.g. Air Con) most motor factors will carry them for £12-£15 or so https://simplybearings.co.uk/shop/pr...ducts_id=60122
Thanks for the Link!
Originally Posted by MB
Anything near the fuel rail is a nightmare and will never be found, ever.Normally I wouldn't muck around with or Rings and stick to OEM, but the MAP one I'd happily use something off the shelf if you can get the right size. Problem is most O rings are sold in kit boxes, so you might get 100 or so, for £20 but you will then have a nice collection.
I found that most are sold in boxes of 215! - I could coat the engine in burnt rubber with that lot!
Originally Posted by Nottm_S2
Hahacant help on o rings but like the storyI dropped a bolt on an engine that wasnt even in the car.2 of us couldnt find it. We put the engine in a van, drove 80 miles, removed it, fiddled with bits and about a week later it was there on the floor, next to the engine.
Thank f**k it's rubber and the size of a 5p piece - what could be the worst that could happen!?
Yeah - I had 5 left over when I did my heated seats....no rattles either!
Originally Posted by E4RTH WORM JIM
I've got 15p nitrate o-rings on my ID1000 injectors. Been on four years and no issue. ID wanted about £20 delivered or something stupid.They just have to be the correct rating for fuel applications.Direct gaskets in Hull got me them. Ring them and they can source or cut anything you require. Great little supplier.They've cut me a gasket for my Tial bov when I lost that, new exhaust gaskets and an exhaust manifold gasket, well I cut that they provide the material
Thanks for the heads up!
simonprelude
05-02-2012 04:19 AM
keysley
04-15-2012 01:47 PM
Nametaek3n
02-04-2009 03:05 PM
sicknesss
04-02-2004 11:43 AM
Paul(UK)
11-27-2003 01:06 AM
Quick Reply: £10 for an o-ring?!
