Clutch Rattle (or Buzz)
Posted 08 April 2004 - 08:40 AM
I was looking to see if someone posted a WAV or MP3 of the noise to be sure that is what I have - but if someone in the area has been through this I could come pick you up and take you for a ride so you could verify the sound.
Thanks!
Dennis
It's not having what you want
It's wanting what you've got
08 S2000 (red)
08 G37 6mt (silver)
06 xB (silver)
02 Honda VTX1800c (black)
03 Honda GL1800 GoldWing (blurple)
Posted 08 April 2004 - 08:44 AM
Dennis
Posted 08 April 2004 - 08:57 AM
The TSB should be on deccelaration it buzzes when engine braking. If that's what yours is doing.....then yep, you got the problem. I would definately go talk to Trickett Honda in Rivergate or maybe try Acura. I've heard Acura dealerships tend to treat the customers better.
Posted 08 April 2004 - 09:25 AM
Quote
BTW, the original owner of my car purchased it in July of 01 - so the car should be under the normal factory warranty and be eligible for the "free" TSB work. I did get the long extended warranty as well, but reading the TSB it looks like that would not be covered under that.
Dennis
Service Bulletin 00-054: Buzzing From the Engine or Transmission While Decelerating
By Erik Petersen on 28/10/2003 01:10 pm
Last modified by Erik Petersen on 28/10/2003 02:05 pm
While decelerating in 3rd or 2nd gear, a buzzing or rattling comes from the engine or transmission between 4,000 and 3,000 rpm. This noise sounds similar to a heat shield rattle, and it goes away if you press lightly on the accelerator pedal or disengage the clutch.
A00-054.pdf 55.35 kB
Yes they should fix it if your car is under warranty or has the extended warranty. I am taking mine to Crest Honda in Nashville for the same thing whenever my car gets finished. They had no problems warranty the work either being since it is a TSB.
Posted 08 April 2004 - 09:52 AM
Yep, I have the HondaCare extended warranty (7 yr, 75k, $0 deductible). It does not cover clutch parts, however.
Dennis
Posted 08 April 2004 - 09:54 AM
Posted 08 April 2004 - 07:38 PM
The catch is that I do not trust any of the dealerships in the area with my car. Especially after talking to the guys in the shop. If anyone can convince me otherwise please feel free. But I wouldnt dream of letting them approach my car for something like the clutch work.
Keep calling around though. These dealerships should be doing the TSB's I know for a fact that Waltrip knows about the TSB because they pulled in on my car when they diagnosed the rattle.
If you want me to listen to the rattle I could easily let you know if it is the clutch springs. :)
Posted 08 April 2004 - 09:17 PM
Quote
Do you have Honda Care? Because they will fix it, they have to fix TSB's.
Thought I'd chime in and clarify a little. TSB's do not have to be fixed - some TSB's you don't always want fixed! The Second Gear Grind is one that can cause you more agony after it is "fixed", but the engine/clutch buzz is one that should be a true "all is better now". I learned the hard way (as I am a Honda Dealer) trying to get some TSB's taken care of for Ricosuave that the Honda Care Warranty doesn't cover TSB's. The Honda Care Warranty is basically a really awesome Powertrain Warranty. If you don't get your TSB's taken care of within the first 3 years or 36,000 miles, you're going to have to put up a fight :(
Here is the actual TSB for the "clutch/engine buzz":
There are a few more in my photo album, if you need them - they may be hard to see without enlarging.
Photography at axspot.com. Developing Software at Dealer.com. Writing for Dealer Refresh.
Help
