OEM clutch replacement cost
Old 06-06-2004, 01:05 PM
liquid215's Avatar
Default OEM clutch replacement cost
Clutch just started slipping & needs to be replaced. How much is the usual quote for a stock clutch replacement? I'm assuming the parts that would get replaced would be the flywheel & pilot bearing, friction disk, throwout bearing, & pressure plate. Any parts I'm missing?
Also how long does it usually take a Honda mechanic to replace a clutch?
Thanks
Old 06-06-2004, 01:30 PM
cdelena's Avatar
It takes six to nine hours so since labor rates vary it will cost $400 to $800 in labor. Mark up on parts will also vary but the MSRP on OEM parts comes to over $700. Seems like most dealerships quote $1100 to $1400 total.
Old 06-06-2004, 01:43 PM
ImportSport's Avatar
Quote for $1300 here in Nashville. I laughed all the way up to Ganely Honda in Cleveland
Old 06-06-2004, 01:54 PM
liquid215's Avatar
What are all the oem parts needed cdelena? I can prob. save alot of money by buying all the parts myself from site sponser H and A - Accessories.
Old 06-06-2004, 02:27 PM
Popeye's Avatar
I wouldn't think you would need a new flywheel just a resurface; I would consider all new bolts for flywheel and pressure plate though.
Old 06-06-2004, 02:59 PM
FF2Skip's Avatar
[QUOTE]Originally posted by liquid215
Old 06-06-2004, 03:20 PM
cdelena's Avatar
If you replace all parts it will be pilot and release bearings, FW, FD, and PP. They are lower over the web, but not cheap (over $500 plus shipping). You can resurface a FW but Honda does not recommend it and most dealerships will not do it. I don't really think the bolts need to be replaced every time and Honda does not require it. It is very important to get a mechanic that will throughly clean the bellhousing, shaft, guides, and linkage and then lube properly on assembly.
Old 06-06-2004, 03:43 PM
liquid215's Avatar
Thanks for the heads up guys. I'm gonna drop the car off at Honda sometime this week for a quote. Hopefully nothing over $1300.
My car is an '01 with 14K miles. I blame the clutch failure due to lots of stop & go traffic in the area that I live in. Still would have liked to get at least 30K out of the stock clutch
Old 06-06-2004, 11:01 PM
slipstream444's Avatar
http://forums.s2ki.com/forums/showthread.p...threadid=212525
Old 06-06-2004, 11:03 PM
http://forums.s2ki.com/forums/showthread.p...mptech+flywheel
Quick Reply: OEM clutch replacement cost
