need wiring confirmation please!
for tein EDFC:
- All time power supply (Yellow cable): Connect using a branch connector from the all time power supply.
- Accessory power supply (Red cable): Connect using a branch connector from the accessory power supply having sufficient electric capacity such as a cigarette lighter. Caution, if the red cable is connected to the accessory power supply not having sufficient electric capacity, sufficient electric power to operate a motor would not be obtained and also it would have a bad influence on the other electric car components.
- Illumination power supply (Green cable): Connect using a branch connector from the illumination power supply
This is what I would like to confirm:
Green cable -> E
Yellow cable -> D
Red cable -> C
does that look right?
Green cable -> E
Yellow cable -> D
Red cable -> C
rijowysock
09-11-2009 06:09 PM
