How much does a gallon of gas weigh?
Depends on a couple of variables but I will make a couple of assumptions for simplification.
1.) 93 octane gas is in liquid form (specific gravity = .76).
2.) Different brands of 93 octane gas is of same density.
3.) You are referring to U.S. Gallons
1 (gal of gas) * .76 (gm/cm^3) * 1/.000264 (cm^3/gal) * 1/1000 (kg/gm) * 9.81 m/s^2 = 28.24 (kg*m/s^2)= 28.24 Newtons =
6.35 lbs.
Here are my references:
http://www.hess.com/about/msds/Gaso_Prem_0324_clr.pdf
http://www.digitaldutch.com/unitconverter/
6.35 lbs.
[QUOTE]Originally posted by Kaptain Insano
[B]Depends on a couple of variables but I will make a couple of assumptions for simplification.
1 (gal of gas) * .76 (gm/cm^3) * 1/.000264 (cm^3/gal) * 1/1000 (gm/kg) * 9.81 m/s^2 = 28.24 (kg*m/s^2)= 28.24 Newtons =
S2Kguy never said how precise he needed the calculation.
The difference in the solutions could be quite significant.
I hope you are not engineering bridges for any city I live in.
