What is hypoid gear oil?
Old 04-16-2002, 11:56 PM
VtecF20's Avatar
Default What is hypoid gear oil?
I'm going to be changing the differential oil this weekend and ust wondering what the significance of hypoid gear oil is. I read many threads regarding the differential oil change but don't recall the explanation of hypoid. Only reason I ask is because I'm planing on using Mobil 1 synthetic gear oil which does not state that it is a hypoid type. I'm just trying to follow Honda's fluid requirements whcih calls for hypoid GL5 or GL6.
Old 04-17-2002, 12:29 AM
JaminBen's Avatar
Hypoid? Doesn't that refer to the cut of the gear's teeth? I think so. Hypoid gear oil = oil for hypoid Gears.
I believe Hypoid designates the type of Gear, not the type of Oil.
Anyone else?
Old 04-17-2002, 03:48 AM
cdelena's Avatar
[QUOTE]Originally posted by JaminBen
[B]Hypoid? Doesn't that refer to the cut of the gear's teeth? I think so. Hypoid gear oil = oil for hypoid Gears.
Old 04-17-2002, 05:23 AM
Testut's Avatar
cdelena,
A nice review. Thanks for passing it along.
Old 04-17-2002, 09:50 PM
VtecF20's Avatar
Thanks for the insight on hypoid gears. Just wanted to make sure before I change fluids...Mobil 1 it is!
Old 04-18-2002, 12:53 AM
JaminBen's Avatar
cdelena,
a big thank you for this and other super-informative posts!!!!
This is what makes internet and forums worthwhile
Old 12-21-2010, 04:54 PM
s2000man's Avatar
The difference between a spiral bevel and a hypoid is the offset of the pinion. With a spiral bevel, the centerline of the pinion axis meets the centerline of the gear axis. They only have a rolling motion, like the cylindrical gears in the transmission.
With a hypoid set, the pinion centerline is offset either above (typical front axle in a 4x4) or below (typical rear axle) the gear centerline. This makes for a larger pinion head, but also causes a sliding motion. The sliding pretty much scrapes away the oil film of a standard oil, and you get metal to metal contact. As long as you have an oil with an EP additive and the right viscosity you should be fine.
Old 12-21-2010, 08:33 PM
starchland's Avatar
honda motorcycles division produces a gear oil labelled 'hypoid gear oil'
http://cart.parkwaypowerhouse.com/product_...products_id=254
Old 12-22-2010, 03:02 PM
Bror Jace's Avatar
"Honda motorcycles division produces a gear oil labeled 'hypoid gear oil' "
I see it's rated for GL-4/GL-5. That's good. I hope it holds up better than the stock/factory oil that Honda uses in our cars. That crud is shot after 10,000-15,000 miles.
Old 12-22-2010, 09:08 PM
starchland's Avatar
ironic isnt it considering the factory oci is far greater than that?
I would hope Honda motorcycles come FF'ed with something more stout
Quick Reply: What is hypoid gear oil?
