Brake Caliper and Bracket Torque Specs
I have changed my rotors and I need help with the torque specs. I need to know the following:
-Caliper Bracket Torque Spec Front and Rear
-Caliper Mounting Bolt Torque Spec Front and Rear
-Banjo Bolt Torque Spec Front and Rear
Thank you in advance for any help you can give.
Car is a 2002 model.
i did an install for my stoptech brakelines a while back i remember the banjo bolts were to be set at 14 lb/ft. not sure if thats oem, but thats according to stoptech
