Fuel Injector Leaking
One of the fuel injector is leaking at the arrow below. Right where the hole in the injector is.
What causes it to squirt fuel out of that hole? Is it a sign that injectors are bad or is it something else that is wrong that causes the fuel to squirt out that way.
Originally Posted by Vanishing Point,Sep 16 2008, 08:12 PM
Probably you have a partially obstructed injector. Does it leak at low or high rpm?
Originally Posted by 2poor2mod,Sep 17 2008, 09:55 AM
ray it looks like you have a torn o-ring on the top of the injector, i would replace the o-ring and double check for a leak.
Yeah, go to Lowes or HDepot plumbing dept, pick up a #78 o-ring for a buck, and you're golden.
When you install the fuel rail, though, smear a bit of oil on that o-ring, stick it in the fuel rail, and do the same with the rest injectors, THEN put the whole assembly in a pre-oiled manifold.
Good luck!
Good luck!
S2Ki FTW!
