Jump to content
Page 1 of 1
change headlight bulbs
#1 User is offline   boiii4
  • Group: Guest
  • Country: United States
Posted 01 January 2009 - 11:15 AM
how to change the headlight bulbs? any ideas? thanks
#2 User is offline   s2k aok
  • Group: Guest
  • Gender:Male
  • Interests:i TOP ALWAYS DOWN !
Posted 01 January 2009 - 04:33 PM
surprisingly i haven't had to change out the bulbs yet...
Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image <img src='http://www.s2ki
#3 User is offline   dezymond
  • Group: Guest
Posted 01 January 2009 - 09:39 PM
haven't attempted to change my bulbs yet, but i have on my other cars.
the only thing different for the S, i think you have to remove the front bumper to get to the headlights, could be wrong.I did read about it somewhere on this forum, search it.
#4 User is offline   Neutered Sputniks
  • Group: Guest
  • Gender:Not Telling
Posted 02 January 2009 - 01:30 AM
^^You're doing it wrong...
You should be able to reach behind the headlights through holes in the engine compartment...
Posted Image
Triple-H: "to try and describe the roads "here" would be like trying to define the last digit of Pi. "
#5 User is offline   boiii4
  • Topic Starter
  • Group: Guest
Posted 02 January 2009 - 10:59 AM
dont you have to unscrew the something or just turn the socket?
#6 User is offline   dezymond
  • Group: Guest
Posted 02 January 2009 - 07:37 PM
like i said i never changed my bulbs in the S yet. In my other cars i know it's just a simple twist of the bulb, pop-out , and replace.
when i was reading about changing the bulbs in the S, i kept reading that the front bumper had to be removed.
i am thinking of getting 5000k or 6000k bulbs though, anyone got any good prices?
#7 User is offline   S2Sloww
  • Group: Guest
Posted 02 January 2009 - 09:54 PM
#8 User is offline   mr_grand_prix
  • Group: Guest
  • Gender:Male
Posted 03 January 2009 - 12:24 PM
You do have to remove your front bumper or try to go through the fender liner..
you will need a 25m torx to unscrew the bolt to replace the HID bulb.
I would uninstall the front bumper to be safe and to prevent you from not seeing what u are doing. Its time consuming but very easy.
Hope this helps.
Posted Image
#9 User is offline   Neutered Sputniks
  • Group: Guest
Posted 04 January 2009 - 10:11 PM
Hope this helps.
Funny...I managed to replace both turn signal bulbs without removing the bumper or liner. I'd imagine that since the turn signals are further into the fender than the headlights I could change the headlight bulbs without removing the bumper or liner. Oh well, what do I know, I've been wrong before :hello:
This post has been edited by Neutered Sputniks: 04 January 2009 - 10:12 PM
#10 User is offline   marksae
  • Group: Guest
  • Gender:Male
Posted 29 January 2010 - 01:42 AM
I just changed my headlight bulbs. The security screw is a T25 Torx tamperproof screw. So I didn't have a short bit of that size. All I had was a screwdriver, so it was too long to stick into access hole from the engine compartment.
I ended up taking off my front wheels and pulling back the fender liners to access the bulbs. It wasn't that bad. Just a bit tedious removing all those clips and bolts. But the end result was worth it. 6000K bulbs look much better than the OEM 4300K. :D
07 LBP S2K
09 E90 AW M3 6MT
#11 User is offline   ryanfeldman
  • Group: Guest
Posted 29 January 2010 - 11:43 AM
same as above. replaced them with 8000K bulbs for more of a hint of blue but still bright without any visability loss. just took off the wheels and fender liners.
Exterior: OEM Hard Top - JDM Clear Side Markers - Window Tint - Blue Calipers - A Sport Bumper - A Sport Side Skirt Splitter - Seibon CF Hood
Interior: VooDoo Shift knob - Seat Covers - Heated Seats - CR Floor Mats - CR Shift Boot - CR Radio Door
Engine: Fujita Cold Air Intake - JMB Powdercoat - Cross Brace Cover - Front Heat Shield - HKS Hi-Power Dual Exhaust - BERK Test Pipe
ICE: Pioneer Headunit - Polk Components - JL Sub - JL Amp - JL Stealth Box
#12 User is offline   newyawkballa
  • Group: Banned
  • Gender:Male
Posted 30 January 2010 - 10:06 PM
I have Ignited performance 8000k bulbs.I think i paid $120 for the pair.The visibility is almost as good as stock.
Ads by Google   S2KI
Share this topic:
Page 1 of 1
