Introducing Adam's Waterless Wash
Adam's Polishes Waterless Wash...
Why Go Waterless?
Your car doesn’t always need a full bath with soap and water. Save water, less sloppy, and it's quicker!
How Does it Work?
Spray on moderately dirty finish, wipe clean with our a Waffle Microfiber Towel.
Special lubricants and wetting agents encapsulate dirt, and make it easy to clean without water.
How is it different than our Detail Spray?
The Waterless Wash is a more effective cleaner, and has more lubricant designed to remove larger dirt particles without issue.
Follow the Waterless Wash with Detail Spray to enhance gloss, and perfect the details!
Adam’s Waterless Car Wash
Pros: Prolong wax and sealant durability. It can also be used in the sun!
Cons: If used with a dirty towel, or on an excessively dirty car, micro-scratching is possible.
Do you still need to wash your car with Shampoo and water? Absolutely! After a storm, during the winter, or whenever there is excessive dirt or large pebbles of dirt on your finish, you will still want to treat your vehicle to a traditional wash.
Click here to pick some up at a special introductory price: Adam's Waterless Wash
Why Go Waterless?
How Does it Work?
you want to always use a clean mf towel. this product is one for the owner that has no access to water. of course you want to use all these with proper common sense.
I would say the more the better. Just to make sure the surface is lubricated enough not to cause and micro-scratching.
Any good plush towel should work, also as long as the towel is absorbent enough.
Why not just call it a quick detailer or a detail spray in the title? Also having experince with tropi-care's, it will run out after about 12 washes or so.
http://www.tropi-care.com/Tropi_Care...ray_p/tc-5.htm
When I think of a waterless wash or eco-friendly wash I think of something that isn't a quick detailer like meguair's and other brands sell.
Cigar Man
10-05-2002 05:53 PM
