Vancouver BC S2000 Owners Meet fellow owners in the Canadian province of British Columbia.
Clutch Master Cylinder Rebuild
Old 01-22-2010, 05:36 PM
VIS2K's Avatar
Default Clutch Master Cylinder Rebuild
Does anyone know where you can buy a clutch and slave cylinder rebuild kit? I hate the thought of spending $450 to replace them when all that's needed is a few rubber pieces and a spring.
I'd rather spend the money on beer
Sorry - alway's wanted to use that smilie.
Thanks,
Mike
Old 01-22-2010, 09:30 PM
DDonovan's Avatar
Try S2S (Duaine), he may know ...,
Old 01-23-2010, 09:33 AM
mavm86's Avatar
Hey Mike,
looks like you can order the individual parts here: http://www.hondaautomotiveparts.com/auto/j...-)&vinsrch=null
or a whole new clutch master and slave for under $160US. How come yours needs replacement? leaking?
Old 01-23-2010, 10:15 AM
VIS2K's Avatar
Thanks Rich and Dave,
I don't believe it is leaking, the fluid level has not changed much, but it gets discoloured in about a year and a half, which means the rubber parts inside the cylinders are deterioriating.
I'm also noticing that the clutch pedal needs to be pressed down farther before it begins to disengage (like the piston is not returning all the way back). The transmission is also getting more dificult to shift, especially into reverse (no syncro).
I've had similar problems with other cars.
I might just take it apart today, clean / polish it and see what happens.
The prices shown certainly are lower than local jobbers here!
I'll post my results - or ask someone for a ride to the dealer
Mike
Old 01-23-2010, 05:16 PM
VIS2K's Avatar
Well, I took everything right apart, cleaned and lubricated it and the clutch pedal is still at the same hieght. I guess I was just paranoid.
What I did notice though was that the ball where the slave cylender meets the clutch fork was corroded and the grease had failed. I cleaned it and covered it in some anti-sieze.
The clutch pedal seems much smoother in operation now (and the fluid is nice and clear again).
FYI I believe this (slave / fork knuckle) can be lubricaed without having to open the hydraulic system. Just remove the 2 bolts that hold it on.
Mike
Old 01-23-2010, 08:11 PM
mavm86's Avatar
Mike
I had read this too. Apparently some people also file down the rough edges on the "ball" where it fits into the "cup".
177ark
09-28-2015 03:48 PM
ktwenty
11-09-2014 12:23 PM
roel03
01-29-2013 07:13 AM
RavynX
01-14-2010 06:56 PM
truekakaka
02-16-2008 01:07 AM
Quick Reply: Clutch Master Cylinder Rebuild
