Re-Installing stock suspension
Make sure the shock is not touching the sway bar, you may need to disconnect both sides and drop it down out of the way to get the holes lined up. I struggled for 30 minutes standing on a breaker bar trying to muscle them in only to realize the sway bar was preventing it from lining up properly!
Here's what I do, works perfectly everytime. You just need a long pipe/rod.
- Disconnect sway bar endlink (just one side)
- Loosen some control arm bolts if you want, but not necessary
- Stick a pipe thru the lower arm, on top of the ball joint, all the way thru so that the far end of the pipe is under the subframe.
- Put some rag between the far end of the pipe and the subframe to prevent scratching.
- Using the subframe as the pivot, press the pipe down on the lower arm. I usually just half sit on the pipe while align the shock bolt.
Loosen all the control arm bushings. You need to do that to clock them for the new ride height anyway. The suspension will droop without resistance if they're all loose.
chinkieboy
11-30-2011 11:02 PM
minboost
05-09-2009 04:12 PM
