stripped bolts on the spark plug cover
Old 07-01-2010, 01:32 AM
redap186's Avatar
Default stripped bolts on the spark plug cover
so some of you may know that i've been having a ignition coil pack / misfire / engine-bog problem with my car,.... well i finally got a used coil pack too replace that cylinder but i now ran into a new problem. i was removing my spark plug / ignition coil pack cover like i usually do and 2 of the bolts came right out but the other 2 are stripped. what do i do 2 get them out so i can change my coils?........ i went 2 honda and they said they would charge 120+ tax too pull them out! i was like DAMMMMMMM!!!!. they said they have to drill and use a special drill bit to reverse pull out the rest of the studs...... is there any other way to get them out that would be way cheaper? i was using a metric 5mm hex key and 2 of the bolts are completely striped inside
the weakkk part is that i have removed this cover PLENTY of times, so its kinda retarded on how tight it was on.
Old 07-01-2010, 07:01 AM
bcs
bcs's Avatar
You could probably buy a drill and the bit yourself for less than $120.
But having the reverse pull out bit is the only way I know of removing stripped bolts. Maybe someone else will have some other ideas.
Old 07-01-2010, 07:02 AM
blacknwhite's Avatar
go to home depot and buy a reverse drill/bolt remover kit. probably about 20 bucks. it is very easy to do. all you need is a drill and a wrench.
Old 07-01-2010, 08:27 AM
s2000Junky's Avatar
I agree, just do it yourself, they are called "easy outs". Then put anti seize on the next bolts you use. These like to stick from the heat and Aluminum expanding/contracting, I’ve had issues with these particular Allen bolts myself.
Old 07-01-2010, 09:04 AM
powdertrax's Avatar
easy out is the way to go. done it a bunch of times, real easy
Old 07-02-2010, 01:03 PM
jerrypeterson's Avatar
This might be a great time to remind everyone that there is absolutely zero need to torque the bolts in question down.
Old 07-02-2010, 02:35 PM
redap186's Avatar
alright i guess ima go n buy a set. how deep should i drill? n thanks for evry1's inputs
Old 07-02-2010, 05:22 PM
s2000Junky's Avatar
There may be enough depth to grab a hold without drilling. Try one of the easy outs without drilling first.
Old 07-02-2010, 08:11 PM
Rdizzle's Avatar
I'm assuming it's the head that strippe right? Another option is to use a dremel tool to cut a notch in the head that will fit a flat head screwdriver. Then just use the screw driver to turn it out.
Old 07-04-2010, 01:41 PM
redap186's Avatar
fixed and pulled the studs. i just used a sock and the 5mm hex bolt hammered it in lol. cave man style hahaha then it came right out. replaced my coil pack now it runs smooth n strong again =)
Quick Reply: stripped bolts on the spark plug cover
