stock AP1 front sway bar vs CR sway bar
Old 09-27-2010, 07:17 PM
shadowz64's Avatar
Default stock AP1 front sway bar vs CR sway bar
Hi,
anybody know if CR front sway bar is thicker than AP1 sway bar???
I believe AP1 sway bar is 28.2mm
How thick is CR sway bar??
let me know~
thanks guys
Old 09-27-2010, 08:44 PM
ShiftGearAP1's Avatar
09 CR-
Front -28.6mm
Rear- 26.5mm
Old 09-27-2010, 08:57 PM
shadowz64's Avatar
Originally Posted by ShiftGearAP1,Sep 27 2010, 08:44 PM
09 CR-
Front -28.6mm
Rear- 26.5mm
thanks for the info
does that 0.04mm make any differences?
Old 09-28-2010, 09:03 AM
hmm, im pretty sure Ap1 fronts are 26.5mm.
If thats the case, then yes it would make a difference. You would decrease the ap1's tendency to oversteer.
Old 09-28-2010, 09:28 AM
chuhsi's Avatar
there's a thread with exact numbers somewhere on this forum.
00 and 01 should be the same thickness as the cr. the 02 and 03 are not as thick as the cr
Old 09-28-2010, 10:44 AM
RAYZ-Ace's Avatar
ya cr sway bar thread also has the specs, i'm not that knowledgable but i dobut you would really notice the difference
Old 09-28-2010, 01:09 PM
shadowz64's Avatar
hmm
I should look that up
thanks for the reply guys
Old 10-05-2010, 08:21 AM
davidc1's Avatar
Switching to the CR bar is the first mod that the SCCA autocrossers suggested I do to my 03
Old 10-06-2010, 10:38 AM
User 121020's Avatar
This should answer your questions about which bars are stiffer and what years they can be found on - Characterization of OE Suspension.
'00-'01 have the stiffest anti-roll bars, front and rear.
Old 10-07-2010, 08:10 PM
thielepr's Avatar
See the differences here from another thread:
Spring Rates:
00-01 Front: 218 lb/in - Rear: 291 lb/in
02-03 Front: 240 lb/in - Rear: 230 lb/in*
04-07 Front: 256 lb/in - Rear: 207 lb/in*
08 Front: 274 lb/in - Rear 225 lb/in*
08 CR Front 375 lb in - Rear 264 lb/in*
*values based on % change data, as lb/in specifications not provided by Honda
Sway Bars Overall diameter X wall thickness
00-01 Front 28.2mm X T5.0 - Rear 27.2mm X T5.3
02-03 Front 26.5mm X T4.5 - Rear 27.2mm X T4.5
04-07 Front 26.5mm X T4.5 - Rear 25.4mm X T4.5
08-? Front 27.2 X T5.3 - Rear 25.4 X T4.5
08 CR Front 28.6 X T4.5 - Rear 26.5 X T4.5
According to that you won't notcie much difference between ap1 28.2 and CR 28.6
Quick Reply: stock AP1 front sway bar vs CR sway bar
