CR Trunk reinforcement
There's been quite a few requests for this, so I took some (slightly better) pictures today.
The CR trunk has a different part number from the non-CR trunk, and it is due to reinforcement to supplement the CR wing.
Please excuse the picture quality, they were taken with my phone
Whole Trunk. All the black things lining the trunk are supports for the trunk; every single one has left a mark on either sheet metal or a support that corresponds to the one on the trunk.
Right side top reinforcement
Right side top reinforcement support (you can see the marks from the top piece)
How the top reinforcement and the support line up
Support at the "bottom" (end) of the trunk
And the mark it leaves on the bumper
left side top reinforcement support (Lighting makes the grooves the top part leaves clearer; this piece is flat brand new!)
And the reinforcement that made the marks
Trunk reinforcement (you only see a little piece here)
You can sort of see ribbing in the hole here.
Same hole, better picture.
Different angle of ribbing underneath the skin.
Same picture but zoomed out so you can see which hole I took it through.
Another picture, different hole. The reinforcement is very obvious in this picture.
And, zoomed out again for perspective
Another picture. I have no idea why that hole is there.
And, zoomed out.
And, a few pictures of my bumper. The wing pushes down hard enough where the bumper is now mis-aligned. The support doesn't actually touch the bumper when the car is parked....
And, zoomed out.
I've already acquired a trunk and wing and need those side support pieces for the car that you name "left/right side top reinforcement"
Anyone know where these are available? I couldn't find it on the exploded diagrams from HAP
Here's the link:
http://www.hondaautomotiveparts.com/auto/j...cgry5=TRUNK+LID
The parts you want are 13, 14, and 15, I think. You'll also need to get the bolts to hold it on (or go to home depot)
Ah damn, ok I just need #14, I was looking in the right place but did not realize that is the part I needed. After reading the description that is exactly what I need. The trunk when I purchased it thankfully already had the two L shaped bumpers so all I needed was the additional bracing on the car itself.
I'm guessing it's just double sided tape on the back of it to hold it in place?
