How do you measure brake disc thickness
Old 02-18-2011, 08:40 AM
s2konroids's Avatar
Default How do you measure brake disc thickness
Not on my S they are fine, my gf said that the garage (dealer) told her the discs are on minimum thickness.
Now I remember them having a lip which is not too bad, but wonder if the garage is fishing for work. Pads have plenty of life in them and discs are not scored.
Is there a way of checking discs without a micrometer and checking if they need replaced? or should I just buy one?.
IIRC discs have the minimum thickness details etc on the side of the disc?
Thanks
Old 02-18-2011, 08:41 AM
The Loon's Avatar
I just run my finger along the edge of the disc - if there's a noticeable lip then its time to change them. Sorry, its not a very scientific method but it works for me
Old 02-18-2011, 08:49 AM
Dixon Motorsports's Avatar
Max lip on both side shouldn't be over 1mm.
The min thickness should always be on the edge of the disk.
Old 02-18-2011, 08:58 AM
s2konroids's Avatar
Cheers dixon and the loon, probably look at it tomorrow.
Old 02-18-2011, 09:01 AM
gbduo's Avatar
Micrometer or Vernier Caliper if they have the small cut out in the caliper.
Old 02-18-2011, 04:18 PM
Banned
gt750boy's Avatar
Lips are not necessarily a problem, it may just mean that the discs need to be turned down, it you can find a miachine shop that will still do this. The only way to measure acurately is with wither a micrometer or vernier calipers. Min thickness should be stamped near the hub.
Lips come from pads that do not fully cover the surface of the disc. Not wishing to teach granny how to suck eggs mind you...
Old 02-18-2011, 09:28 PM
Rogc's Avatar
Use a micrometer, ebay for a tenner, alternatively if you have a vernier calliper, but have a lip on the disk, use a couple of ball bearings put a bearing on each the disk and measure the disk and bearings, fiddly yes, but works.
drives
11-23-2013 08:01 AM
Bandit_287
01-28-2010 11:19 AM
Rob2005
09-13-2008 07:49 AM
russellhq
09-12-2007 05:17 AM
russellhq
06-08-2007 02:42 PM
Quick Reply: How do you measure brake disc thickness
