2nd Gear Grind Fix
Originally Posted by Mark355,Feb 20 2011, 05:53 PM
Painful to watch. Dude thinks he's on Best Motoring.
In any case I dont launch my car and am as ginger as can be to while going first to second. I'll have to be more wary though. Surely with the passage of time this will become a non-issue.
As far as popping out of gears goes. Happened on the Si first winter even though it was built after Honda had discovered and corrected the issue in older VINs. That 3rd gear pop-out has since disappeared as the tranny has broken-in.
On the S I had it pop out of 3rd once, but it was because I had pushed it with half the usual effort .
Dave - Skip shifting is perfectly ok if done the right way is what I've been told. Jackie Stewart recommends it in his book. Never skip shift on the way up but do a 5 to 3 if the corner (not this ) calls for it.
I had the 2nd gear grind till I changed the transmission fluid about 3 years into ownership. The grind (almost) disappeared.
Had the transmission fluid changed again last spring. It came back with a vengeance. Not only does it grind, but occasionally when cold, the transmission will literally pop out of 2nd gear. It is the only gear that does this.
Its all about the transmission fluid I think.
This thread https://www.s2ki.com/forums/index.ph...ic=237209&st=0 talks about it in depth, the S seems to be different in regards to what we know about skip shifting.
Very interesting. Under that scenario of winding out then coast shift to 5-6, I can see the problem. I was thinking about skipping shifts with main and counters at much more relaxed pace. Thanks for sharing this.
This seems to affect 5-6 dog/sleeve, so is independent of 2nd gear grind.
Cool read though.
Cool read though.
Originally Posted by zzziippyyy,Feb 21 2011, 01:59 PM
I respectfully Jackie did not drive nor do I believe he is speaking of modern transmissions with synchros of today.
Out today on a very short drive and I made sure I was extremely patient shifting gears. Second engaged smoothly. I just have to give it that extra split second while the engine and tranny are yet to warm up.
