F22c in AP1
Old 02-23-2011, 10:35 AM
JUSTINTHECOASTIE's Avatar
Default F22c in AP1
Whats up guys, I finally got my first tune today. For those of you that dont know my "set-up" it's nothing special. In fact, it's only average, however, the factor that makes it unique is that it's MY first dyno tune. Thanks John from LHT!!! With his accent and boyish charm, John made my first time I mean tune a big deal....to me hahahaha no homo
Enough small talk on to the "business"....
I have a F22c in my AP1(2005 F22c engine with K&N drop-in and hondata intake heatshield, LHT custom test pipe, AP1 clutch/flywheel AP1 2003 ECU, AP1 2003 transmission, and AP1 diff) tuned with Apexi VAFC 2, tuner was John from LHT Performance
Today, on the first pull, I made 192whp untuned. I cant remember the torque number sorry, please understand I was too excited....Ive "heard" that when doing the F22c swap into a AP1, particularly the 2002-03 models,you should/need to either Aurchase an AP1 2001 ECU w/VAFC or Burchase VAFC. From what I gathered from previous threads on the F22c Swap, you need the older richer(00-01) AP1 ECU because the newer (02-03) AP1 ECU's run leaner. Well today, that fact was incorrect, in fact I was rich very rich multi-million dollar rich @ WOT(I'm RICH B****...rich) Every car is different I guess....moving on....
Final numbers ended up being 224.73whp and 156.66wtq on the dynojet
Before tune
After tuning
Thanks guys :tip wink:
Update: Installed and running Hondata Kpro with 60mm test pipe currently on AP1 basemap
Old 02-23-2011, 10:39 AM
deepbluejh's Avatar
Those are great numbers for an F22c.
Old 02-23-2011, 10:56 AM
Thanks man
Old 02-23-2011, 12:40 PM
EVAN&MONICA's Avatar
The gearing is great when you match the F22 and the AP1 tranny I hear. Very nice numbers as well
Old 02-23-2011, 12:51 PM
Thanks man
Ive also heard good things about a F20 with AP2 gearing, but I havent seen anything in person
Old 02-23-2011, 12:56 PM
what are you revving to?
Looks like about 8300?
Old 02-23-2011, 01:13 PM
It can go to 8.6k easily and take it no problem, however, around 8.3k-about 8.4k is peak curve, from there it slowly drops
Old 02-23-2011, 01:39 PM
H22toF20's Avatar
Great numbers, especially sense this is using a VAFC.
The first pull is VERY rich and choppy. The final tune looks great but it still seems to be a little on the rich side. I wanna see how an EMS would compare.
Old 02-23-2011, 02:25 PM
I wanted it to be a safe tune 12.8 aint too bad this has also started more questions in my mind like what if I had EMS (more control more to gain)
Old 02-23-2011, 10:51 PM
H22toF20's Avatar
It looks closer to 12:1 in spots; sorry I'm a perfectionist. I'm sure being able to control timing and fuel independently would be nice
Quick Reply: F22c in AP1
