disable secondary o2 sensor in flashpro
Old 02-23-2011, 02:11 PM
Swiftoy's Avatar
Default disable secondary o2 sensor in flashpro
Okay, I loaded flashpro with the toda calibration and after fooling aroung with the different menus in flashpro I couldnt figure out how to go about disabling the secondary O2. I could use some help thanks.
Old 02-23-2011, 03:46 PM
Swiftoy's Avatar
Wow after 19 views I figured someone chime in.
Old 02-24-2011, 03:55 AM
scareyourpassenger's Avatar
Did you check the help file?
Old 02-24-2011, 08:41 AM
xredjar's Avatar
Not sure what the problem is...
When you open FP, load a calibration
select the Calibration tab
click on Closed Loop on the left side
at the top there is a checkbox for Secondary oxygen sensor enabled.....uncheck it
hope this helps
Old 02-24-2011, 11:49 AM
Swiftoy's Avatar
I actually found what I was looking for thanks. Now I have the code for the primary that just came up I know there is a tsb for it looks like new primary sensor.
Old 03-01-2011, 06:30 PM
SlowTeg's Avatar
If the secondary o2 sensor is disabled, can it be removed/left unplugged completely, or does it still need to be plugged in (or it'll throw a code)?
Old 03-02-2011, 08:59 AM
Swiftoy's Avatar
Why would you want to completely remove it if it can be disabled. Just seems like a lot of extra work to remove the sensor.
Old 03-02-2011, 06:01 PM
SlowTeg's Avatar
You have to be kidding, right? Work to remove a sensor? You mean unscrew it and unplug it from the harness? lol You can easily use a plug for the hole.
I guess I'd have to ask why you'd even WANT to leave it connected if you're disabling it in the first place..? To add, for those fabbing up a straight pipe, it means one less bung you have to weld in for the secondary o2.
Hopefully someone can now chime in whether the o2 sensor can be removed entirely/unplugged w/o throwing a code.
Old 03-05-2011, 01:34 AM
psychoazn's Avatar
Bump, I'd like an answer too
Old 03-07-2011, 05:38 AM
Swiftoy's Avatar
Maybe you enjoy getting under a car all the time or maybe you have access to a lift I don't! It's very easy to remove no doubt but is Pretty F*****g simple to just disable with the software uncheck the box and your done and leave well enough alone. To each there own.
Quick Reply: disable secondary o2 sensor in flashpro
