speedometer stopped working, EPS light on
AHH so i stopped at a gas station and filled the car up and when i left i noticed my speedo stopped working then shortly after the EPS light came on. Anybody have a clue to what is going on?
New search must not suck all that bad. It led me here. Picked up my car today after a clutch change and had the same symptoms. My yellow box is under the console and the connector must have worked loose when the shifter was put back in. I snugged it back up and we're all good now.
In my case the EPS light was intermittant and the strangest part was when I stopped the car at idle I could pull the steering wheel left to right once and let go and it would move the same range left to right by itself until I stopped it. Freaky.
This very thing happened to me a while back and my yellowjacket had failed giving the symptoms you describe. Installed a new yellowbox and it has been fine since.
goldenfri
10-15-2007 01:31 PM
