turn signal issue
Old 04-11-2011, 11:38 AM
ftpsk8's Avatar
Default turn signal issue
So recently I bought a set of rear turn signal LED bulbs off ebay (bad idea). Put them in, and they dont work. So I tried putting my oem bulbs back in, and now they dont even work. Checked the oem bulbs, and their fine. Checked fuses, their fine. Checked the connectors for the turn signals and they are getting power. Only thing I haven't checked is the relay I think. My front turn signals are still working fine. Only thing I can think of is maybe I'll have to buy new connectors because the LED bulbs messed them up somehow.. I have no clue what the problem is, maybe someone can help me out here.
Old 04-11-2011, 02:09 PM
whippets2k's Avatar
So you used a voltmeter to make sure there is power to the connection? Did you look inside the connector and notice if the contacts were bent/misaligned and not hitting the contact on the bulb? Was the bulb put in upside down (not sure if that makes a difference)?
Old 04-11-2011, 02:36 PM
SheDrivesIt's Avatar
It certainly does on the leds since they have polarity.
Old 04-12-2011, 06:08 AM
AngryTurtle's Avatar
bulbs are backwards. LED's were too.
Old 04-12-2011, 07:05 AM
ftpsk8's Avatar
Put the LEDs in both ways.
Yes I used a volt meter to make sure there is power to the connection.
The contacts don't look bent or misaligned, but it is kind of hard to tell.
Ive tried putting the bulbs in every way possible and nothing is working.
Old 04-12-2011, 10:52 AM
so you can see the 12v blinking on in the socket with the voltmeter or no?
Old 04-12-2011, 06:51 PM
ftpsk8's Avatar
Well when I tested the connectors with the volt meter, it was saying they were getting power... if thats what you mean.
AndyThomason
12-09-2013 01:34 AM
YDNA
09-30-2012 12:11 AM
a3lkx
12-01-2007 04:06 AM
nixeighty6
08-31-2007 12:55 PM
deepee
03-28-2006 05:04 PM
Quick Reply: turn signal issue
