Sponsor S2000 Suspension, Brake and Handling Deals Sponsor deals on S2000 suspension and S2000 handling products
BC RACING COILOVER and ISC COILOVER
Old 05-10-2011, 02:05 PM
Kami Speed's Avatar
Thumbs down BC RACING COILOVER and ISC COILOVER
KamiSpeed has been offering BC Racing coilovers for many years! We have massive experience with the brand as they are local to us. So we know what setup is best for your S2000!!
BC Racing coilovers strike the best balance between performance and cost. Not only do they offer custom spring rates at no extra charge, we include the rear extenders and shipping!
Perfect for daily driving in the S2k and the occasional dragon run. Throw on a set on Swift Springs and be prepared to autox at will!
$995 SHIPPED
|Standard Features|
|| 10k | 10k springs standard ( Custom spring rates of 4k +|- will require the shock to be re-valved at no extra cost to you! ) ||
|| Mono-Tube Shock Design ||
|| 30 Levels of Dampening ||
|| Pillowball mounts ||
|| Separate Full Length Height Adjustment ||
|| One Year Warranty ||
|| Rebuildable ||
BC Racing newest and most advanced model to date. Features large external reservoirs front & rear. Perfect setup to fine tune your all out track S2K!
$1,850 SHIPPED
|Standard Features|
|| External Reservior Mono-Tube Shock Design ||
|| 30 Levels of Dampening. Rebound on Top of Shock. Compression on reservior. ||
|| Rebuildable ||
|Coilover Add-Ons|
Swift Springs ~ $320 w/ purchase of coilover.
Swift Assist Springs ~ $300 ( Increases comfort and prevents loss of traction during rebound. ) w/ purchase of coilover.
Swift Thrust Sheets ~ $25 ( Allows the spring to smoothly rotate around the perch. Decreases noise level greatly. ) w/ purchase of coilover.
Want a price match or beat? Shoot a screen shot to josh@kamispeed.com
*** S2000 BC BR COILOVERS REVIEW THREAD ***
Kami Speed is here to offer you an amazing combo deal for your S2k!!!
The community knows that when you couple a Swift Spring on a set of coilovers the ride quality and performance of the coilover is greatly improved!
ISC N1 Coilovers +
Swift Spring upgrade for only PM For Price!
Regular set of N1 for $955.00 SHIPPED.
*Two-Year Warranty*
*32 Step Damper Adjustable:*
* Rebound/ Compression adjusted in unison via 32 step adjustment.
*Pillowball Upper mounts:*
* For optimal performance Pillowball Upper mounts are a great feature. ISC Coilovers include pillowball upper mounts on all N1’s.
*Thrust Bearing Kit:*
* We will not charge you 50.00- 100.00 to upgrade to a thrust bearing kit, these are a FREE upgrade on all ISC N1’s. This helps eliminate the chance of spring bind; a common side effect of running aftermarket coilovers.
*Front Camber Plates:*
*Single Cylinder Design:*
* Larger cylinder and piston design to advance driving stability and dexterity.
* Mono-Tube damper with high pressure nitrogen.
* Threaded portion of shaft is powder coated then salt spray coated for optimum street durability- We suggest also using anti seize or other protective products when you install your coilovers for even further protection from the elements if you are exposed to snow and salt.
*Ride Height Adjustable:*
* Full length height adjustable- 3 inches or more on most applications.
* High quality T6061 aluminum alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force.
*Bound Adjustable with Separate Spring Locks:*
* Preload is separate from ride height; the lower you go the ride quality stays the same!
*Aluminum Brackets:*
* Made from T6061 aluminum alloy by organic shaping to lighten weight and increase handling performance.
* ISC Gold or Black anodized surface to help prevent inside corrosion and surface rust.
* Brake lines and mounting brackets are welded onto the bottom mounts *in most applications* for an OEM type installation and fitment.
Custom Spring rates of +4 | -4 allowed. Please allow 1 week build time on the coilovers if in stock! Price includes shipping within continental US, add tax in FL.
Kami Speed is offline
Old 05-10-2011, 02:36 PM
StrokerAce's Avatar
pm price for all series shipped to 92880
StrokerAce is offline
Old 05-10-2011, 03:24 PM
dj-
dj-'s Avatar
pm price for BR type shipped to 98295
Thanks,
dj- is offline
Old 05-10-2011, 07:34 PM
F20NA's Avatar
pm price shipped to 01801 all models..
Thanks
F20NA is offline
Old 05-11-2011, 11:39 AM
Kami Speed's Avatar
Pmd!
Old 05-11-2011, 09:30 PM
hypforlife32's Avatar
bought a set today! free bump
hypforlife32 is offline
Old 05-12-2011, 10:29 AM
Kami Speed's Avatar
Thanks for the all the orders guys!
Old 05-13-2011, 08:50 AM
Kami Speed's Avatar
bump!
Old 05-13-2011, 12:26 PM
hyb1212id's Avatar
Pricing shipped to 90731 for both systems please.
hyb1212id is offline
Old 05-13-2011, 02:04 PM
venge's Avatar
Price on br system shipped to 94597 please
venge is offline
Quick Reply: BC RACING COILOVER and ISC COILOVER
