S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
What is the lowest aftermarket seat and rail combo you can get?
Old 05-24-2011, 10:23 AM
hkchung113's Avatar
Default What is the lowest aftermarket seat and rail combo you can get?
I am 6'2", 34" waist, 180 lb, with board shoulder. I sit way too high with stock seat and after I did the seat mod to lower the stock seat, I still sit too high to see traffic light when I am the first car.
Do you know what is the lowest aftermarket seat and rail combo you can get to get the lowest sitting position? I did the search on this forum and I got a mixed bag of answer. So far, I narrow down my choice to Recaro SPG or Pole Position with Buddy Club rails. In term of sitting height is the SPG and Pole Position about the same? I think I am too wide for SPG. I heard that BC rails give you the lowest sitting position on S2000 but their quality sucks...but I am willing to have the spot weld redo if it has the lowest sitting position.
Have you guys heard of Nagisa rails? are they as low as BC rails?
I am just looking for the lowest sitting position on the S2000, I am open to suggestion.
Thanks in advance!!
Old 05-24-2011, 12:04 PM
//steve\\'s Avatar
Buddy Club rail and Recaro Pole Position. You could probably squeeze into the SPG if you wanted but you'll definitely be more comfortable in the Pole Position. With either of those seats on the BC rail the bottom of the seat will be about 1/2" from the carpet.
I'm 6' 235lbs 36 waist. and fit in that setup just fine. With the seat like that my head doesn't even stick above the factory rollhoops and I don't even need the seat as far back as it can go.
Old 05-24-2011, 02:02 PM
hkchung113's Avatar
I saw this old post that has a picture that show BC and Nagisa rail side by side, and the Nagisa rail is significantly lower...
Old Seat thread (The picture is about 3/4 way down the thread)
Can anyone tell if the seats in the pictures are Recaro Pole Position.
Thanks!
Old 05-24-2011, 05:12 PM
stradleboy's Avatar
Bolt the seat to the floor?
Old 07-20-2011, 08:50 AM
Savedsol's Avatar
Those are Profi SPG
killerpenguin21
08-05-2016 02:03 PM
Fagan
05-08-2013 12:56 AM
sharksfinn
10-08-2009 10:13 AM
phatjoe
05-18-2009 10:10 AM
LostMotion
09-26-2007 08:53 AM
Quick Reply: What is the lowest aftermarket seat and rail combo you can get?
