Slight hesitation at low RPM
Hi Gang.
Got my '07 AP2 last week and finally made it to the DMV yesterday for registration. I'm officially in love Anyway, the hesitation issue. Say I'm driving along and traffic in front of me comes to a stop. I coast in neutral but then traffic starts moving again before I can stop. At this point, say I'm at about 11 MPH, I put it in 2nd gear and I start to accelerate again. What happens is, it starts going but after a few hundred RPMs, it hesitates, then starts going again and everything is cool.
Seems to happen only at low RPM between 1500-2500 although I haven't gotten a chance to give this car a romp yet. I did a little research and some older threads suggest heat soak but I'm not quite sure that's what it is. Others say your close to idle speed and when you press the gas the ECU doesn't really know what to do yet. Another possibility is that it's just a quirk w/the DBW system. I don't know.
Any help would be great. I'm hoping I don't have some sort of problem with it, cuz if I do then it's
2007 w/31k miles
Thanks Gang!
2007 w/31k miles
Thanks Gang!
My '06 does the same thing, but only when the engine is hot. I have read others that have the same symptom. I think it has to do with the stock tune, it doesn't bother me enough to spend the money on a aftermarket tune.
ROD
ROD
try cleaning your throttle body plate, my car drives so much more smoother now. I cleaned both the Idle air control valve and the throttle body plate both of which were caked in carbon build up. To access the throttle body plate all you have to do is remove the air intake tube and you will see the plate inside. With the car OFF, open it so that it is completely open and wipe away with a clean rag with carb cleaner on it (clean both sides)The car idles so much more smoother and does not bog whatsoever. I have a 2002 s2k.
dont forget to clean the iacv (idle air control valve).There is a DIY on this somewhere, You just loosen the 2 bolts holding it and loosen the vacuum hoses and clean the metal rollers and chamber. Also reset the ecu by pulling the correct fuse and let it idle for a few minutes. Good luck.
I have the same issue, i posted a thread recently with no real feedback, I have an 07 with 25K.
Its definitely a hesitation after the throttle delivers power briefly, then backs off, then its there again, and its intermittent, and lower RPM 2500-3500. It feels like when VSA cuts power for traction control.
