vin location on engine?
Old 07-19-2011, 10:07 AM
ForkYou's Avatar
Default vin location on engine?
I'm trying to locate the vin number on my engine and I'm having a hard time locating it ...
Can someone please tell me where it is .
Thanks
Old 07-19-2011, 10:11 AM
Stratocaster's Avatar
it is NOT on the Block. The block has a serial number that does not match the VIN. The head has a VIN on the very back side, next to the firewall. You will be hard pressed to see it without pulling the head out of the car.
Old 07-19-2011, 10:28 AM
Billman250's Avatar
Received 1,244 Likes on 759 Posts
VIN location is on the green plate on the cyl head. note other things in the pic...upper starter bolt sitting in hole, infamous ground wire on back of cyl head, main oil gallery plug, rear main seal.
Old 07-19-2011, 10:32 AM
Great picture Bill.
Here is a current thread on the same topic.
https://www.s2ki.com/s2000/topic/882...-stickers-are/
Old 07-19-2011, 09:43 PM
SpitfireS's Avatar
The VIN plate on the head is a US thing only?
Old 07-20-2011, 03:33 AM
It must be based on your post in the other thread.
Old 07-20-2011, 08:05 AM
ForkYou's Avatar
How much would it cost to pull the head off and just get the vin number ? A Rough estimat? Or billman how much for you to just et me my vin numbers ?
I need the vin numbers to confirm some improtant information.
P.S. = thanks for all the info guys!
Old 07-20-2011, 08:27 AM
Billman250's Avatar
That would be a real bad idea to pull the head.
Just use a dental mirror and get your VIN.
AP1 will start with JHMAP1
AP2 will start with JHMAP2
If you came to me no charge of course to read the numbers.
The trans has a VIN also that matches the car VIN. it is on the right side of the trans, under the car.
Old 07-20-2011, 05:06 PM
Banned
HondaRehab's Avatar
You'd be crazy to pull the head to get the vin. You think your motoro is stolen or something?
Old 07-20-2011, 05:13 PM
f20kills's Avatar
My 02 had a sticker on the front block with the VIN IIRC. Next to the crank pully...I could be wrong as that block is long gone lol
Quick Reply: vin location on engine?
