Velocity Stack
Old 09-22-2011, 06:02 PM
IanGrimmy's Avatar
Default Velocity Stack
worth it for a dd s2k?
either way getting a 3" pipe made for it, either gonna just throw a filter on it or get a velocity stack, cant make up my mind...
Old 09-22-2011, 06:37 PM
zeroptzero's Avatar
Received 3,361 Likes on 2,444 Posts
a velocity stack is always a great idea, that's why the oem honda air filter has a velocity stack built into its base. One reason why I don't like the K&N replacement filter for our cars is because it doesn't have a built in velocity stack, though the K&N FIPK intake has a velocity stack on it.
Old 09-22-2011, 07:40 PM
wisdom's Avatar
Is there an option to add a velocity stack to the stock intake arm and order a larger K&N filter?
Old 09-22-2011, 10:59 PM
H22toF20's Avatar
The FIPK velocity stack is a joke.
I'm running a BPI velocity stack with my set-up. The BPI has been proven to see gains by putting it on(B and H series). It was so good, Blox copies the design.
Here's the FIPK vs the BPI
Old 09-23-2011, 11:55 AM
S~Factor's Avatar
Where can that be purchased?
Old 09-23-2011, 11:15 PM
H22toF20's Avatar
Here you go. I know there are some old threads on HT about it.
http://www.bpinitiatives.com/
Old 09-24-2011, 12:33 AM
emphany's Avatar
blox stack with filter for 50ish shipped on ebay
Old 09-24-2011, 09:50 AM
rrounds's Avatar
Not cheap but well made and I like aluminum.
http://www.turbohoses.com/velocity_stack.htm
ROD
Old 09-24-2011, 11:16 AM
Gernby's Avatar
http://www.turbohose...ocity_stack.htm
ROD
The stacks they show are more like half stacks, since the flange is a "quarter round" instead of a "half round" like the BPI stacks. Depending on the implimentation, I could see one being better than the other. However, I think I'd rather have a composite matierial instead of aluminum to reduce heat capacity.
Old 09-24-2011, 06:25 PM
it'S2klean's Avatar
I don't know much about velocity stacks. Where do you put that sucker?
Quick Reply: Velocity Stack
