CEL P1415 After izze simulation install
Posted 27 November 2011 - 05:37 AM
"If everything seems under control, you're just not going fast enough."- Mario Andretti . My ruckus http://totalruckus.c...057409#p1057409
Posted 27 November 2011 - 02:28 PM
If you connect the white simulator wire to the wrong side of the white/black oem wire (ECM plug 31P, #24), you'll throw a P1415 code. The white simulator wire must only attach to the side of the white/black oem wire going into the ECM. An example of this is shown in Page 4 of the instructions.
Keep me posted,
Caleb
"He who follows another is always behind."
Posted 27 November 2011 - 08:42 PM
Posted 27 November 2011 - 09:43 PM
Theoretically a very low battery voltage could trigger a P1415 code.
Posted 28 November 2011 - 12:41 AM
Posted 28 November 2011 - 06:39 AM
If you can, check the small gauge oem white wire (large gray plug) with a voltmeter. It should read battery voltage.
If you don't have a voltmeter, check to see if the trunk popper button works (in the glove compartment), the simulator feeds off the poppers constant 12V.
The fact that the CEL comes on right away tells me it's either not getting the correct amount of voltage it needs, the ground is bad, or the white wire isn't hooked up correctly (you already checked this).
Caleb
Posted 21 February 2012 - 11:45 PM
i dont think my battery is low because it start right up even after couple days
Posted 22 February 2012 - 07:41 AM
DaveOnLI....RIP till we come together again....
Volks 16" CE28N , 04 trans, 04 driveshaft, 04 dif, Fujitsubo Exhaust, Rick's 6plus header, T1R test pipe, Comptech: icebox, flywheel, oldschool silver STB, rear tie bar, ACT PP, Billman's shortshifter, Billman's lifetime Gen3 TCT, aluminum pulleys, race pedals
Posted 27 February 2012 - 09:27 PM
What should I check? I am running an IZZE Engineering kit, but I have been running it for a few months without issue. I didn't even pull out my air pump. I just used the kit to pass emissions.
Posted 28 February 2012 - 08:28 AM
It is the izzy kit, or the wiring. Where it it mounted/ Maybe they disturbed it during the detail.
Posted 28 February 2012 - 01:54 PM
Posted 27 March 2012 - 07:04 AM
As I've now said many times, the simulator is only as good as the installation. You must triple check your connections (correct wire? secure connection? good ground?) and check the constant battery voltage source/wire with a voltmeter – as stated in the instructions. I only include the squeeze connectors for those who absolutely cannot solder, please solder if you can.
P1415 could be caused by an incorrect connection at the OEM white/black (ECM plug 31P, #24) wire. This OEM wire must be cut, and the white simulator wire must be attached to OEM white/black wire leading into the ECU (leave the other side of the white/black OEM wire unattached).
I understand wiring isn't for everyone. In designing this module, I tried to use as few connections as possible; however, I cannot make it any simpler than it is now. The USDM air pump monitoring system is quite complex, accordingly, it requires multiple connections. Out of all the simulators I've sold (and I've sold quite a lot) two customers had faulty ECU's, that is, they were throwing air pump CEL's because the transistor that controls the OEM red wire (plug 32P, terminal #2) had failed – before the simulator installation. All other issues were because of incorrect wiring or a blown fuse for the constant voltage source. If it's a USDM S2000, your ECU is good, and you installed it correctly, the simulator will work.
ookielookie,
Like Bill said, it's likely the detailer accidentally yanked/pulled one of the simulator wires loose. If you used the squeeze connectors, the connection is very susceptible to being unattached. Check all of the simulator connections and solder if you can. Please keep me posted.
Thanks,
Caleb
Posted 27 March 2012 - 04:00 PM
Posted 27 March 2012 - 04:47 PM
Help
