S2KI Honda S2000 Forums: Calling FI s2ks...emission time once again - S2KI Honda S2000 Forums
Jump to content
  • 2 Pages +
  • 1
  • 2
#1 User is offline   Spec_Ops2087
  • Group: Member
  • Gender:Male
  • Country: United States
Posted 21 December 2011 - 09:55 PM
Yes, it's that time again - my emissions sticker is up this month and I'd like to bring the s2k to shop and get it inspected. Down side is my AEM EMS obviously will not pass. I'm pretty sure I still have all the emissions related parts. Would I be able to esentially swap my stock injectors + stock ECU into the car and still have her work with the turbo and what not installed (obviously I would be driving like a grandma)? My main concern would be misfire codes / CAT ready code / and maybe my EGR valve since I removed that - all codes that would fail the car....
Any suggestions?
2009 Rutgers Mechanical / Aerospace Engineering Alumni
My Photography and Art-----My Videos
#2 User is online   Deception
  • View gallery
  • Group: Member
  • Gender:Male
  • Interests:s2000's, MR2's, computers, architecture, art, tattoos, women, cigarettes, ps3, devil music.... and so on
Posted 21 December 2011 - 10:23 PM
Get the Izzy Engineering air pump delete kit, once you wire it into the ECU harness you will never have to worry about that crap again. I think its $100.
O2 de-fouler for the test pipe. Take out the wastegate spring to be safe. Swap stock injectors & ECU, should be good to go.
Just need to drive 50 miles or so to set the ECU readiness.
Its basically the same as what I do, only Im S/C'd now so instead of pulling the wastegate spring I remove the SC belt.
'00 Silverstone w/ 05' F22, SOS 1200 kit, stock exhaust, test pipe... 15psi @ 8500 rpm = faster than stock.. used to be turbocharged
'92 Sentra SE-R, 75k miles, NX brake upgrade, getting it ready for boost
#3 User is offline   Spec_Ops2087
  • Topic Starter
  • Group: Member
  • Gender:Male
Posted 21 December 2011 - 10:35 PM
I actually just purchased it reading one of your older threads, thanks :)
Is there anyway to false the secondary O2 sensor? My EGT sensor is directly behind the turbo and I'm not sure if I want to put the primary O2 sensor in this location. My AEM A/F gauge sensor is located where the secondary O2 sensor would approximatly be located if I had the stock exhaust and that's where I planned on putting my primary O2 sensor. There are no more bungs for the secondary sensor...any way to fake it?
#4 User is offline   Phill24
  • View gallery
  • Group: Member
  • Gender:Male
Posted 22 December 2011 - 06:46 AM
go to pepboys boys or any parts store buy a spark plug non fouler 42009 i believe the part number is...its 2 in a pack ur gonna drill 1 of them with a 1/2 drill bit the other stays the same...screw ur o2 sensor in the 1 u drilled out then screw them both together and install in o2 sensor location u should be good to go after that
#5 User is offline   Spec_Ops2087
  • Topic Starter
  • Group: Member
  • Gender:Male
Posted 22 December 2011 - 09:06 AM
So I wrote up a list on things I have to switch back to drive on the stock ECU without a CEL:
1. Wire in the airpump delete kit
2. Reinstall stock MAP sensor
3. Reinstall the stock injectors and remove resistor box
4. Reinstall the stock ECU
5. Reinstall the O2 sensors
6. Remove the intercooler piping so no boost gets to the motor
I think that covers it, correct me if I'm wrong...
BTW, stock ECU can run with a 3mmHG without a CEL correct?
#6 User is online   PUNCHIN-IT
  • View gallery
  • Group: Member
  • Gender:Male
  • Interests:Cars & bikes. Vrooooooom!
Posted 22 December 2011 - 11:51 PM
That's crazy. I think if you go to shea stadium junk yard you can pay them around 250 to pass you. I did it when i was turbo charged. had CEL and everything. I don't know how they did it, but it worked.
- Formally known as "nyczs2k" -
My Seller Feedback
Posted Image
#7 User is offline   Spec_Ops2087
  • Topic Starter
  • Group: Member
  • Gender:Male
Posted 23 December 2011 - 08:53 AM
Assuming I have all of the parts, I can install everything in a few hours so it's not that big of a deal as long as the car can run with a 3mm HG with the stock ECU. I think I might just be missing a few parts...
#8 User is online   Deception
  • View gallery
  • Group: Member
  • Gender:Male
Posted 26 December 2011 - 11:07 AM
AFAIK the car will run OK (no cel) with 3mm HG & stock ECU. Your list looks complete, I forgot about the MAP sensor.
#9 User is online   Deception
  • View gallery
  • Group: Member
  • Gender:Male
Posted 26 December 2011 - 11:10 AM
damn 250, I went to a place that was $100. But you can only do that every other year. When you renew registration every 2 years you need to get a "real" inspection
#10 User is online   PUNCHIN-IT
  • View gallery
  • Group: Member
  • Gender:Male
Posted 26 December 2011 - 01:42 PM
Ohh really nice. I never knew that lol
#11 User is online   Soul Coughing
  • Group: Member
  • Gender:Male
Posted 27 December 2011 - 03:23 PM
Car will run fine with a 3mm headgasket and the stock ECU. I will have to do this again this coming january and i think i'll just purchase one of those airpump deletes depending on how well his works for you. If you have your wideband connected to C16 on the wiring harness you'll have to reinstall the stock wiring too. I used a quick connect connectors for it so i could reattach these things easily.
#12 User is offline   Spec_Ops2087
  • Topic Starter
  • Group: Member
  • Gender:Male
Posted 28 December 2011 - 09:32 PM
^^ Yep, luckily I also had simple spade connectors so that was easy to plug back in.
Still looking for some OEM injector clips / MAP sensor clip... :(
#13 User is online   PUNCHIN-IT
  • View gallery
  • Group: Member
  • Gender:Male
Posted 04 January 2012 - 12:35 AM
So did you ever get the S to pass emissions? If so what did you have to do to get it to work?
#14 User is offline   Phill24
  • View gallery
  • Group: Member
  • Gender:Male
Posted 04 January 2012 - 06:43 PM
x2^^^^
#15 User is offline   Spec_Ops2087
  • Topic Starter
  • Group: Member
  • Gender:Male
Posted 07 January 2012 - 12:40 AM
Just got all the parts to put the fuel / emissions system back to stock. I'll start converting back this week with a inspection test hopefully next weekend / week.
#16 User is offline   Billman250
  • View gallery
  • Group: Community Organizer
  • Gender:Male
  • Interests:S2000 Repair
Posted 08 January 2012 - 08:28 AM
I have a better idea. Call me :)
Billman250 S2000 Repair
DaveOnLI....RIP till we come together again....
Posted Image
Volks 16" CE28N , 04 trans, 04 driveshaft, 04 dif, Fujitsubo Exhaust, Rick's 6plus header, T1R test pipe, Comptech: icebox, flywheel, oldschool silver STB, rear tie bar, ACT PP, Billman's shortshifter, Billman's lifetime Gen3 TCT, aluminum pulleys, race pedals
#17 User is offline   NFRs2000NYC
  • Group: Moderator
  • Gender:Male
  • Interests:32MPG Club!
Posted 09 January 2012 - 06:12 AM
I was gonna tell you the same thing Bill is going to tell you. ;)
Posted ImagePosted Image
Posted ImagePosted ImagePosted Image<img sr
#18 User is offline   Spec_Ops2087
  • Topic Starter
  • Group: Member
  • Gender:Male
Posted 12 February 2012 - 05:40 PM
I just got back into town the other day and went to get the s2k inspected - passed with flying colors so now I'm good till 2013.
So if anyone wants to know, with spark plug nonfoulers + stock injectors / MAP sensor / ECU + air pump delete a turbo s2k can pass no problem. You just have to remember to never get into boost with the stock ECU which isn't as easy as it sounds :p
Now to reinstall the parts + oil change + new HID bulbs (since mine were getting dim) and I'll be ready for the spring :)
#19 User is online   dales2000
  • Group: Guest
  • Gender:Male
Posted 12 February 2012 - 07:54 PM
couldnt you just disconnect one of the intercooler pipes to ensure the ecu never sees boost?
TURBO!!!!
Ptuning kit, haltech 1000, ID1000s, gt3076r, 340whp at 7 psi stock exhaust recirculated dump Evans Tuned!
#20 User is online   S~Factor
  • Group: Member
  • Gender:Male
Posted 12 February 2012 - 08:15 PM
Nice!!! :thumbup:
#21 User is offline   Spec_Ops2087
  • Topic Starter
  • Group: Member
  • Gender:Male
Posted 12 February 2012 - 11:18 PM
You could but I didn't have a filter cone that would fit the piping and I don't like running the engine without one. Either way, just have to use a light foot and it's all good.
#22 User is online   Soul Coughing
  • Group: Member
  • Gender:Male
Posted 13 February 2012 - 03:28 PM
Very cool, I'll be doing the same thing in the next couple weeks. You got the 60 dollar air pump delete kit right?
#23 User is online   JoeyBalls
  • View gallery
  • Group: Member
  • Gender:Male
Posted 13 February 2012 - 08:35 PM
Can someone PM me the illegal way. I dont care how much it costs, I am not putting the stock stuff back in the car...................
635/456 Q16
Posted Image Posted Image
002 by JosephCostanza, on Flickr
#24 User is offline   skoundrel
  • Group: Member
Posted 14 February 2012 - 05:16 PM
Is it even possible on an OBDII car?
#25 User is online   JoeyBalls
  • View gallery
  • Group: Member
  • Gender:Male
Posted 15 February 2012 - 12:07 PM
??? Do they need to have something plugged in to print the sticker?
Ads by Google   S2KI
Share this topic:
  • 2 Pages +
  • 1
  • 2
